12-14-2017 11:34 AM - edited 03-08-2019 01:06 PM
In order to recovery the switch, I have to use the xmodem protocol to upload the ios image to flash as opposed to tftp via the Ethernet Ports. What could be the reason why the ports are not functioning in Rommon Mode ?
12-14-2017 11:49 AM
12-14-2017 11:55 AM
12-14-2017 12:00 PM - edited 12-14-2017 12:01 PM
You can't and it won't.
The "instructions" about the ethernet ports are found in the IOS itself.
The only way to hasten the upload speed is to use the "-s <SPEED>" (see instructions below) to increase the baud rate.
Xmodem Console Download Procedure Using ROMmon
Are you sure this is a "plain" 3560 and not a 3560E or a 3560X?
12-14-2017 12:21 PM
So, what your saying is that I'll have to utilize the console cable to do an ios upload and manipulate the (baud rate) transfer speed. Because the boot loader does not have the ability to activate the Ethernet Ports
12-14-2017 12:52 PM
Switch Model: Layer 3 Switch -Cisco Catalyst 3560 PoE 24 Port
