Catalyst 3560 - L3 Inter Vlan Routing - No connectivity to firewall
steve_deboeck
I've been working on my home lab and can't seem to figure out what I'm doing wrong.
I have multiple VLAN's:
10: USERS
20: SERVERS
30: WIFI
100: MANAGEMENT
200: INTERCO
My C3560 switch is connected to a Zyxel USG60 Firewall. The point is to do the inter vlan routing on the Switch of course and the Firewall doesn't need to do anything else but be a way out to the internet.
The LAN port of my Firewall has IP: 10.5.200.1 255.255.255.252
I configured this on my Switch:
ip routing
vlan10
name users
int vlan 10
ip add 10.5.10.2 255.255.255.0
vlan 20
name servers
int vlan 20
ip add 10.5.20.2 255.255.255.0
vlan 100
name management
int vlan 100
ip add 10.5.100.1 255.255.255.0
vlan 200
int vlan 200
ip add 10.5.200.2 255.255.255.252
ip dhcp pool VLAN10_USERS
network 10.5.10.0 /24
default-gateway 10.5.10.2
dns-servers 8.8.8.8 8.8.4.4
ip dhcp excluded-address 10.5.10.1 10.5.10.29
int gi0/2
desc My PC
switchport mode access
switchport access vlan 10
My PC got IP 10.5.10.30 /24 with gateway 10.5.10.2 I can ping my switch correctly
The routing between vlans works. I can access my server on vlan 20
My switch can also access my firewall on IP 10.5.200.1
My PC can't access my firewall.
A traceroute stops at my switch.
I saw a similar (but not entirely same) case on these forums and someone suggested to add:
ip route 0.0.0.0 0.0.0.0 vlan200 10.5.200.1
I tried this. Didn't change anything.
I also saw someone proposing to do L3 connectivity between switch and router (by doing no switchport and adding an IP on the interface itself) but I haven't tried this yet.
Is there like a best practice in this kind of case? What is the ideal configuration? What am I doing wrong?
I added my network topology so you can visually understand what I'm saying here :-)
I would appreciate if you could share some of your wisdom with me.
Kind regards,
Steve
dbeattie
Has your firewall got an internal-facing route? It will need to know how to get back to your PC. Should look like:
Route to 10.0.0.0/8 via 10.5.200.2
(or similar e.g. 10.5.0.0/16 or all of your /24s)
Dave
6 Replies 6
dbeattie
Dave
Hey Dave,
That is one of the possibilities I also considered but I figured since it was working when using only VLAN1, I presumed it had an implicit route but I guess it makes sense that if I introduce a new "router" (L3 switch), I have to tell my firewall how to get to those other networks (VLAN's).
So I should create a policy route using following info (see screenshot as example of the Zywall interface)
Incoming: interface
member: any
Source: any
Destination: 10.5.0.0/16
next-hop
type: interface
interface: lan1
I don't think I have the possibility to choose an IP as next-hop but sending it out of the LAN port should be fine I guess. The L3 switch will handle it.
I'll definitely try this tonight and will mark your answer as solution if it works :-)
Steve
Even better. Thanks :-)
It is certainly important for your firewall to have a route for your additional subnets. Another question to consider is about address translation. I would expect your firewall to perform address translation for the subnet of its lan interface. But will your firewall also perform address translation for the additional subnets you have configured on the switch?
Rick
Rick
Adding the route immediately worked. No need to some NAT explicit NAT.
Thank you very much.
