Catalyst 3650 and SG200 Etherchannel
amantsios
recently we bought 2 SG200 to expand our network to Gigabit.We own 1 Catalyst 3650.
We tryed to Etherchannel between the Catalyst and one SG200 but with no luck.
At Catalyst i created the port channel
interface Port-channel1
switchport mode access
and put 4 ports on it
interface GigabitEthernet0/45
channel-group 1 mode on
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
when i do show interface port-channel 1 i get that
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 001a.a24d.00ae (bia 001a.a24d.00ae)
  MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi0/45 Gi0/46 Gi0/47 Gi0/48
  Last input 00:00:16, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 988000 bits/sec, 166 packets/sec
  5 minute output rate 1943000 bits/sec, 224 packets/sec
     3283827412 packets input, 3257328668 bytes, 0 no buffer
     Received 34678609 broadcasts (0 multicast)
     10 input errors, 10 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 8423441 multicast, 0 pause input
     1976995515 packets output, 241528325 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
I can see that the port-channel is 4Gbit but into the SG200 web interface the Link stays at 1Gbit
I also tryed speed tests but the link is still 1Gbit.
I also giving you 2 screenshots from the sg200.
Am i doing something wrong?
Do you have any suggestions?
Is able sg200 to create etherchannel with the Catalyst?
Thanks in Advanced
Alex
6 Replies 6
SunilKhanna
See from the output of SG200, LACP is Disabled.
I would suggest,
1. Enable LACP oin SG200
2. Used command "channel-group {Number} mode active" on CISCO side.
If you think the steps mentioned helped you, please rate the post.
Regards, Sunil Khanna
i tryed that also before but with no luck.
When i do that i get Success but LACP is still disabled.
Check out the screenshot.
Any other suggestions?
Alex
HI,
I see the LACP checkbox unchecked, please correct that.
Cheers,
Sunil
When i check the Enable box and then hit Apply i got the screenshot i just send.
It says Success but it doesn't enable it.
From CISCO side, could you please share the output of "sh ether summ"
Sunil
sw1#sh ether summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi0/45(P)   Gi0/46(P)   Gi0/47(P)
                                 Gi0/48(P)
