Catalyst 3650 flexible netflow on svi
uzleuven1
Is there a reason why 3650 does not support netflow on SVI's?
We use vrf lite extensively so we use SVI's and trunks for the uplinks and no routed ports.
Jose Solano
Level 4
Level 4
The switch does not support netflow on SVI and tunnels. See link below:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/flexible_netflow/configuration_guide/b_fnf_3se_3650_cg/b_fnf_3se_3650_cg_chapter_010.html#reference_C63398C01C7C41E1AEC2BCEE4915A909
Thank you.
I know it is not supported.
I just wondered why Cisco does not support it?
They make such a big fuss about visibility in this platform.
Are there so many people that use routed interfaces on campus access layer switches?
If you then want to use vrf's you need a whole lot of uplinks :)
