Catalyst 3650 OS image not auto booting after restart
Jack96
9 Replies 9
Leo Laohoo
Did someone conduct password recovery on the switch?
Not recovery password and I saved the boot image but after restart boot is entering rommon
If the switch is still in ROMMON, post the complete output to the command "set".
If the switch has successfully boot into OS, post the complete output to the command "sh romvar".
this is romvar result
CS#show romvar
ROMMON variables:
0x2102=""
ASIC_PCI_RESET="1"
BOOT="flash:/packages.conf"
BOOT_LOADER_UPGRADE_DISABLE="1"
BYPASS_STARTUP_CONFIG="= 0"
CFG_MODEL_NUM="WS-C3650-24TS-L"
CLEI_CODE_NUMBER="IPMV810BRE"
CSR_PCIERST_DISCONNECTED="yes"
DEFAULT_GATEWAY="192.168.100.1"
DEFAULT_ROUTER="192.168.10.1"
D_STACK_DOMAIN_NUM="1"
ECI_CODE_NUMBER="470063"
IP_ADDR="192.168.10.10/255.255.255.0"
IP_ADDRESS="192.168.100.12"
IP_SUBNET_MASK="255.255.255.0"
MANUAL_BOOT="0"
MODEL_NUM="WS-C3650-24TS"
MODEL_REVISION_NUM="R0"
MOTHERBOARD_REVISION_NUM="A0"
MOTHERBOARD_SERIAL_NUM="FDO22322VX5"
RECOVERY_BUNDLE="sda9:cat3k_caa-recovery.bin"
SCH_IGNORE_STARTUP_CFG="1"
SWITCH_IGNORE_STARTUP_CFG="= 0"
SWITCH_PRIORITY="2""
TAN_NUM="800-41246-03"
TAN_REVISION_NUMBER="D0"
TEMPLATE="advanced"
TERMLINES="0"
TFTP_FILE="cat3k_caa-universalk9.16.12.12.SPA.bin"
TFTP_SERVER="192.168.100.10"
VERSION_ID="V04"
boBOOT="= flash:packages.conf"
boot="= flash:packages.conf"
Post the complete output to the command "sh boot".
Console into the switch and reboot.  Post the entire boot-up process.
CS#show post
Stored system POST messages:
Switch 1
POST: MBIST Tests : Begin
POST: MBIST Tests : End, Status Passed
POST: CRYPTO Tests : Begin
POST: CRYPTO Tests : End, Status Passed
POST: PHY Loopback: loopback Test : Begin
POST: PHY Loopback: loopback Test : End, Status Passed
POST: Thermal, Temperature Tests : Begin
POST: Thermal, Temperature Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: SIF Tests : Begin
POST: SIF Tests : End, Status Passed
just want to help there
he use two
BOOT="flash:/packages.conf" <<- this config files
are this correct ??
MHM
Jens Albrecht
Looks like someone has screwed up the ROMMON variables:
You need to clean up this mess and then check again.
