Loss of configuration after reboot
HatDauNho
Hi team,
I have a Switch C9200 and every time I reboot, the configuration is lost. I don't know why.
I wonder if it's because the flash is lost?
Jens Albrecht
Hello @HatDauNho,
sounds like someone has set the flag to ignore the startup-config when the switch boots.
Use the command
no system ignore startupconfig switch all
to restore the default behavior, i.e. loading the config file when the switch boots.
If this does not help, then post the entire output of the commands 'show boot' and 'show romvar'.
HTH!
7 Replies 7
mg_avo
Did you check the flash afterwarts? Did you see any logging entries?
Did you change anything regarding the config register?
Example doc: https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
M02@rt37
Hello @HatDauNho
do show romvar command and see variable on line SWITCH_IGNORE_STARTUP_CFG=
If it is 1, so tat the problem !
Best regards
Jens Albrecht
Hello @HatDauNho,
Use the command
HTH!
Hi @Jens Albrecht,
I have tried that command and the issue has been resolved, thank you. But may I ask what is the cause of this problem where the configuration could not be saved?
Hi @HatDauNho,
glad to hear that it is working.
In fact the config was saved. However, as the name implies the Ignore_Startup_Cfg flag tells the switch to ignore the startup-config. So the config was still there but not loaded when the switch booted.
Please do not forget to mark the previous post as 'solution provided'. Thanks!
You Q must be why this command run' even if I dont manually add it?
I think either because
You do password recovery
Or
Zero touch config
MHM
Jens Albrecht
Yes, most of the time someone did a password recovery or factory reset and forgot to reset the ROMMON variables back to default.
