Catalyst 3650 Switch
abhishek-nath
Community Member
We are using Catalyst 3650 Switch for our internal testing and we wanted to know which PHY model is used in the Switch design for further analysis
  - @abhishek-nath           Cisco does not provide those info's
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
Hello @abhishek-nath
do that command:
show controllers ethernet-controller gigabitethernetX/X/X phy detail
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/consolidated_guide/command_reference/b_consolidated_3650_3se_cr/b_consolidated_3650_3se_cr_chapter_011.html
and check PHY IDs like this:
In my case if I combine the 2 PHY ID I have in Hex 0x002063B0 => It is what we call the PHY Identifier Register (PHYIDR1/PHYIDR2 combined).
After, that I need to check that PHY ID regarding constructors PHY ID database ...
Best regards
Thanks for the response !
I guess i haven't made myself clear enough, i apologize. I am basically looking for PHY Model/Manufacturer Part Number details used on the Ethernet ports for the Hardware design analysis. If anyone can share that details, it will be really helpful.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Mmmm OK.
So, Mr Elsen answers to you.
Best regards
