Catalyst 3750 E slow ping response
I'm not sure if this is expected behaviour or not. I discovered this while troubleshooting an intermittent network issue which I still haven't solved. Until it is solved, anything is suspect and this behaviour seems odd to me. Is there something wrong here, or this this just how the switches work?
We have offices on both sides of the street, the south side subnet is connected to the north side subnet via radio link (600Mbps full duplex). Routing is done on our layer 3 switches (Catalyst 3750E-48TD-S running ipbasek9 IOS 12.2(55)SE12). Each subnet (South and North) have a Netgear firewall/router to connect to the outside world. The equipment on each side of the street has identical configs to their counterparts on the other side (except for which subnet each one belongs to).
First strange behaviour:
The catalyst 3750Es seem to have a network datagram size limit only on traffic within the local subnets. For instance, from the south side 3750E the biggest ping packet I can send to any host in vlan 25 is 5940 bytes. Anything 5941 or bigger does not make it back. similarly pinging from a host withing vlan 25, the biggest packet that is returned from the South side 3750E is 5912 Bytes. But from any host in vlan 25, including from the South 3750E, I can use significantly larger packets to successfully ping hosts on the other side of the street, including to the North side 3750E.
Second Strange behaviour:
Pings to the Catalyst switches take longer to return than pings to the netgear routers or to Windows hosts. For example, from a windows host on the south side sending 6912 byte ping packets to windows hosts or netgear router on the other side of the road takes on average 1ms but pinging the North side Catalyst switch with the same size packet takes on average 6ms.
Third Strange behaviour
Pinging from any host on the south side of the road to any windows or netgear host on the other side works well up to maximumum packet size of about 6900. Anything over 7000 bytes starts dropping progressively more packets until 8000 bytes where about 90% of packets are lost. But I can ping from Catalyst switch to catalyst switch across the road using the largest supported packet size of 18024 bytes with no losses. I suppose this could be explained by the fact that pinging from windows hosts on side of the road to the other involves routing but pinging from the catalyst to the other catalyst on the other side of the road is not routed. But if I do (from the North side switch) ping 10.0.25.253 repeat 10 size 18024 Source 10.0.20.253, does not that involve routing, to get from the 20. subnet  to the road crossing subnet?
Here is config from the south side switch:
! Last configuration change at 14:35:22 PDT Sun Apr 22 2018 by bleuze
! NVRAM config last updated at 09:07:01 PDT Mon Apr 23 2018 by bleuze
version 12.2
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname sw-stone-rtr
boot-start-marker
boot-end-marker
enable secret 5 $1$52Ab$2XZoY3kXCaLJOUDqRPFW21
username bill privilege 15 secret 5 $1$.ja3$6lidw202ZzIAo4u2PsNDV0
username admin privilege 15 secret 5 $1$YboL$AF31tx51SR9kmGMIay3w6.
username bleuze privilege 15 secret 5 $1$o5Ck$rhxvt2KYFqxEjlZRHAY3j/
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
switch 1 provision ws-c3750e-48td
system mtu routing 1500
ip routing
no ip domain-lookup
ip domain-name colonial.local
ip host tftpd 172.16.254.30
ip host ccv-vCenter 172.16.254.30
vtp mode transparent
crypto pki trustpoint TP-self-signed-1885815168
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1885815168
 revocation-check none
 rsakeypair TP-self-signed-1885815168
crypto pki certificate chain TP-self-signed-1885815168
 certificate self-signed 01 nvram:IOS-Self-Sig#3838.cer
archive
 path tftp://172.16.254.30/sw-stone-rtr/$h-$t
 write-memory
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree portfast bpduguard default
errdisable recovery cause bpduguard
errdisable recovery interval 360
vlan internal allocation policy ascending
vlan 20
 name CCV-Lam
vlan 25
 name CCV-Stone
vlan 254
 name Management
vlan 500
 name Voice
interface FastEthernet0
 no ip address
 no ip route-cache cef
 no ip route-cache
 no ip mroute-cache
 shutdown
interface GigabitEthernet1/0/1
 description stone users
 switchport access vlan 25
 switchport mode access
! identical interfaces lines removed for brevity...
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
 description VMware ADD Port2
 switchport access vlan 254
interface GigabitEthernet1/0/43
 description ccv-vCenter mgmt
 switchport trunk native vlan 25
interface GigabitEthernet1/0/44
 description Stone Router
interface GigabitEthernet1/0/45
 description mgmt port
interface GigabitEthernet1/0/46
 description stone shop
interface GigabitEthernet1/0/47
 description Road Xing
 switchport trunk native vlan 254
 switchport mode trunk
interface GigabitEthernet1/0/48
 description to router
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan20
 no ip address
interface Vlan25
 ip address 10.0.25.253 255.255.255.0
interface Vlan254
 ip address 172.16.254.154 255.255.255.0
ip default-gateway 10.0.25.254
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.25.254
ip route 10.0.20.0 255.255.255.0 172.16.254.153
no ip http server
ip http secure-server
vstack
alias exec start-tftp copy startup-config tftp://172.16.254.30/sw-stone-rtr.cfg
line con 0
 exec-timeout 0 0
 logging synchronous
line vty 0 4
 exec-timeout 120 0
 login local
 transport input all
line vty 5 15
 exec-timeout 30 0
 login local
 transport input all
ntp clock-period 36029663
ntp server 10.0.20.55
end
gaston.benitez
Level 3
Level 3
I share an interesting link regardin MTU on 37xx devices. You can try to enable jumbo frames. Also for traffic between hosts in vlan 25 to hosts in vlan 20 you can test the MTU that Ubiquitys are configured for.
// Cisco Catalyst 3750/3560 Series Switches - Jumbo/Giant Frame Support Configuration
https://support.hpe.com/hpsc/doc/public/display?docId=c03331307
BR
Gaston
Joseph W. Doherty
Regarding 2nd strange behavior - Cisco devices often give low priority responding to ping replies - in fact, to account for internal delay, some Cisco devices support IP SLA responders, which adjust latency measurements to account for the extra delay.
