Catalyst 3750 Radius Authentication-1
egemen1981
I am trying to configure 802.1x configuration on Catalyst 3750,
I am starting as a creating new aaa model, by using "aaa new-model" command.
But after I execute this command switch start to as for username and password on telnet session. How can I disable radius authentication on telnet and console session.
Thanks.
6 Replies 6
mrdogantr
     try to config below.
line vty 0 4
no login local
password cisco
enable secret cisco
hth
Muammer
You can disable the Radius authentication on telnet and console by applying the below commands in the config mode.
#set authentication login radius disable console
#set authentication login radius disable telnet
Please click on the correct answer if this answered your question.
Naidu.
Switch does not recognize these command in privilege or config mode ?
In which mode should I enter them?
Try below...
Console> (enable) set authentication login radius disable
radius login authentication set to disable for console and telnet session.
Console> (enable) set authentication enable radius disable
radius enable authentication set to disable for console and telnet session.
Console> (enable) show authentication
Naidu.
How can I enter console mode (console>) ?
I think it is different from privillege mode?
Can you try below in global config mode.
no login authentication
Naidu.
