catalyst 3750
jackrivituso
Community Member
Regarding catalyst 3750's, is spanning tree set by default or do I have to code for it? If so, what is the code? thanks!
lamav
Level 11
Level 11
Jack:
What do you mean "code for it"?
Spanning tree is enabled by default on all Cisco Catalyst switches.
Victor
To activate spanning tree, is there a line of coding I have to add to the configuration?
Again, spanning tree is enabled by default on all Cisco Catalyst switches.
