Catalyst 3750X Reset to Factory Default
dacruzer1
Is there another way I can reset my Catalyst 3750X to factory default besides holding down the Mode button because it did not work for me (several times).  I pulled the switch from a stack.  Any help would be appreciated.
Thanks, Alfred
2 Accepted Solutions
Hello Not sure why this hasn't worked it should have http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/3750x_3560x_HIG/HGTRBL.html#wp1060415 Do you have a console cable attached when you reset the switch? Res Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you can can "log on" to the device (console?) you should be able to erase startup.
Kind Regards
Paul
Hi Paul,
I was consoled in and I was able to run the command "write erase" and the delete "vlan.dat"  After the the reload, the switch was still showing the stacks, so I ran the "no provision command" and the reload again.  It finally worked.
Thanks!
Joseph W. Doherty
Disclaimer
Posting
Hi Joseph,
Thanks!
