Catalyst 3850 high Total output drops and output errors
Antony Pasteris
We have put in service a catalyst 3850-12XS running ver 03.07.03E and we have noted that in certain ports, there is high output drops.  Auto QOS is configured on this switch and we have tried removing the qos config on the ports having problem but it didn't change anything.  From a performance point of view, at the moment the switch is running without problems... there is no network outage.
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is 00cc.fc68.f681 (bia 00cc.fc68.f681)
Description: VLAN 599 XXXXXXXX
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 128/255, txload 16/255, rxload 10/255
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:19, output never, output hang never
Last clearing of "show interface" counters 10:12:51
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 249067352
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 41672000 bits/sec, 6894 packets/sec
5 minute output rate 65358000 bits/sec, 8267 packets/sec
69357766 packets input, 54278801831 bytes, 0 no buffer
Received 1362 broadcasts (1226 multicasts)
0 watchdog, 1226 multicast, 0 pause input
97533479 packets output, 108964531997 bytes, 0 underruns
249067352 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
As you can see from the ping below that's sending traffic through the link described above, there seem to be no connectivity issues apart from the fact that the output drops counter indicate something completely different.
XXXXXX#ping 4.2.2.1 repeat 1000 size 100
Sending 1000, 100-byte ICMP Echos to 4.2.2.1, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 10/14/30 ms
Could this be a bug ?
48 Replies 48
The counters are showing the amount of bytes dropped not packets.
Below is the bug id.
From TAC "Here is the bug id that states the output drops counters are in bytes: CSCuu56537."
bytes dropped \ bytes out * 100= percentage of drops.
bobybravo
AMP does not provide integration with Active Directory in the intervening time, however there's a script available, wherein you may sync Active product page of Directory (LDAP) Groups with AMP corporations, please take a glance
AlexBravo
Similar problem here but Reliability looks solid so far (255/255).  Packet drop ratios seem to be commensurate with traffic volume for affected interfaces, but out overall throughput on any given interface tops out at 25% so we're pretty sure it's not a matter of high traffic specifically.
alexhaji
Any resolution to these issues?  I am having the same problem.  I began occuring after the upgrade to 03.06.05.E.  I noticed it initially on WAN interfaces that are limited to 10Mb by the WAN provider.  TAC chalked it up to spikey traffic and we played with QoS policies and queue buffer ratios trying to get it the errors down with only intermittent success.
This week I connected two access layer switches (a 2960S and a 2960X) to copper 1Gig interfaces on the 3850.  There is relatively little traffic going across these links (peak of 40Mbps today), but I am getting the same continuous output errors.  It appears to be related to queue thresholds being exceeded, but there are no policies assigned to these interfaces.  So that doesn't really make sense.
