C3650 SIF POST failed
zhikun xiong
Hello All,
I had a brand new C3650 recently.  It only worked for 3 days, and I got error message "BIST fail. Abort init..." suddenly. So I followed Bug search tool to upgrade firmware from 3.6.6E to 3.7.4E, and the error message is gone. But I got another message "Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager].[SIF POST failed]". Now I'm stuck. Does anyone have this error before? Any ideas to fix?
Danny
Contact Cisco TAC and organize for an RMA.
22 Replies 22
balaji.bandi
Looks like you hitting with another bug :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup57468/?rfs=iqvred
Try troubleshoot  :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/201070-Troubleshooting-3650-3850-reloads-by-sta.html
BB
zhikun xiong
Hi BB,
Thanks for the information, but I don't understand because my switch doesn't have any stack kits. I don't know why get stack error. I will try to troubleshooting.
Danny
Can you Power off the device and connect to the cable and post the complete boot process.
Once it booted, can you post the below outcome :
show version
show boot
dir
BB
Hi BB,
The switch just keeps booting, so I only can force it into rommon mode.
Danny
Here comes:
Booting...
Interface GE 0 link down***ERROR: PHY link is down
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Reading full image into memory....done
Reading full base package into memory...: done = 81992100
Bundle Image
Kernel Address : 0x5377834c
Kernel Size : 0x3fb4ba/4175034
Initramfs Address : 0x53b73808
Initramfs Size : 0xd47999/13924761
Compression Format: .mzip
Bootable image at @ ram:0x5377834c
Bootable image segment 0 address range [0x81100000, 0x820b0000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 623
Loading Linux kernel with entry point 0x816734a0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=4,mode=600,ptmxmode=000 0 0
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
Apr 25 08:43:00 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
Apr 25 08:43:00 %STACKMGR-1-RELOAD: Reloading due to reason SIF POST failed
<Sun Apr 25 08:43:00 2021> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [SIF POST failed]
get_local: failed: No such file or directory
Unmounting ng3k filesystems...
Unmounted /dev/sda3...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
Booting...
Bundle Image
Apr 25 08:49:01 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
Apr 25 08:49:01 %STACKMGR-1-RELOAD: Reloading due to reason SIF POST failed
<Sun Apr 25 08:49:01 2021> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [SIF POST failed]
Restarting system.
Booting...
Booting...
The system has been interrupted prior to initializing some
filesystems and loading the operating system software.
Console will be reset to 9600 baud rate, need to change terminal setting first.
The following commands will initialize the remaining filesystems,
and finish loading the operating system software:
flash_init
boot
switch: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address. -f to flush
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dig -- Lookup a name via a remote dns server
dir -- List files in directories
emergency-install -- Initiate Disaster Recovery
flash_init -- Initialize filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
mgmt_init -- initialize management port
mkdir -- Create dir(s)
mlog -- In-memory log control
more -- Concatenate (display) file(s)
net-debug -- Show/change network debug val
net-dhcp -- Initiate DHCP request for remote configuration
net-show -- Show network parameters
net-tcp-bufs -- see/set tcp number of buffers
net-tcp-mss -- see/set tcp mss
net6-dhcp -- test dhcpv6
net6-show -- Display ipv6 info
ping4 -- Send ICMP ECHO_REQUEST packets to a network host
ping6 -- Ping v6 host
readrtc -- Read RTC
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
writertc -- Write RTC
switch: dir flash:
Directory of flash:/
30977 drwx 4096 .
2 drwx 4096 ..
30978 -rw- 2097152 nvram_config
30979 -rw- 81992100 cat3k_caa-base.SPA.03.07.04E.pkg
30980 -rw- 5667516 cat3k_caa-drivers.SPA.03.07.04E.pkg
30981 -rw- 36656136 cat3k_caa-infra.SPA.03.07.04E.pkg
30982 -rw- 46349632 cat3k_caa-iosd-universalk9.SPA.152-3.E4.pkg
30983 -rw- 28904332 cat3k_caa-platform.SPA.03.07.04E.pkg
30984 -rw- 128582464 cat3k_caa-wcm.SPA.10.3.141.0.pkg
30985 -rw- 1236 packages.conf
1288916992 bytes available (358977536 bytes used)
switch:
Completely wipe out the switch, re-configure it, and tested again
  1. Format the flash:
  2. re-install the IOS Fresh Code Following below document:                                                    https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html#anc20
BB
Hi BB,
The switch had problem with set IP_ADDR and DEFAULT_ROUTER too. I had setup many times, but it just can not ping from switch to TFTP server or the reverse. So I used the USB drive to install eventually. I don't know is it will be problem if I completely format the flash and using USB drive to install because I can not copy files to flash during rommon mode. Or should I backup all flash and sda9 files before I do the emergency-install? Here is my last time emergency-install process.
switch: emergency-install usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin
The bootflash will be erased during install operation, continue (y/n)?y
Starting emergency recovery (usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin)...
Reading full image into memory.......................done
Bundle Image
Kernel Address : 0x537965d4
Kernel Size : 0x41852f/4293935
Initramfs Address : 0x53baeb04
Initramfs Size : 0xe77ac6/15170246
Bootable image at @ ram:0x537965d4
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
File "sda9:cat3k_caa-recovery.bin" uncompressed and installed, entry point: 0x8166a600
Loading Linux kernel with entry point 0x8166a600 ...
Initiating Emergency Installation of bundle usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin
Reading bundle usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin...
Validating bundle usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin...
Installing bundle usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin...
Verifying bundle usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin...
Package cat3k_caa-base.SPA.03.07.04E.pkg is Digitally Signed
Package cat3k_caa-drivers.SPA.03.07.04E.pkg is Digitally Signed
Package cat3k_caa-infra.SPA.03.07.04E.pkg is Digitally Signed
Package cat3k_caa-iosd-universalk9.SPA.152-3.E4.pkg is Digitally Signed
Package cat3k_caa-platform.SPA.03.07.04E.pkg is Digitally Signed
Package cat3k_caa-wcm.SPA.10.3.141.0.pkg is Digitally Signed
Preparing flash...
Syncing device...
Emergency Install successful... Rebooting
Restarting system.
Booting...
Bundle Image
Apr 24 08:56:30 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
Apr 24 08:56:30 %STACKMGR-1-RELOAD: Reloading due to reason SIF POST failed
<Sat Apr 24 08:56:30 2021> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [SIF POST failed]
Restarting system.
Booting...
Danny
Instead, install Try below Option :
switch: dir usbflash0:
switch: boot usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin
is this boot and works and you get Switch>  prompt?
BB
Hi BB,
No, this command got same error message then rebooting...
Booting...
flash_init
boot
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
usbflash0[10]: (read-write)
flash[19]: (read-only)
tftp[20]: (read-write)
ftp[21]: (read-only)
http[22]: (read-only)
switch:
Directory of usbflash0:/
4 -rw- 328157104 cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin
5 -rw- 310347344 cat3k_caa-universalk9.SPA.03.07.00.E.152-3.E.bin
6 -rw- 257016048 cat3k_caa-universalk9.SPA.03.03.00.SE.150-1.EZ.bin
6507016192 bytes available (895520496 bytes used)
switch:
Reading full image into memory............................................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address : 0x53796290
Initramfs Address : 0x53b9174c
Bootable image at @ ram:0x53796290
File "usbflash0:/cat3k_caa-universalk9.SPA.03.07.04.E.152-3.E4.bin" uncompressed and installed, entry point: 0x816734a0
Apr 25 18:51:55 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
Apr 25 18:51:55 %STACKMGR-1-RELOAD: Reloading due to reason SIF POST failed
<Sun Apr 25 18:51:55 2021> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [SIF POST failed]
Restarting system.
Booting...
1.  Download the latest 16.3.X and force the switch to boot this image.  Do not boot from USB.  Instead copy the firmware (from USB) to the flash and then boot the firmware from the flash.
2.  Can I see the first SEVEN (7) characters of the serial number of the switch?
Hi Leo,
I had downloaded the 16.3.9 firmware, but I can not copy it to flash since the switch keeps rebooting. The flash always is read only in rommon mode. I tried to set switch_ignore_startup_cfg=1, but still can not copy after the switch rebooted. Is there any way else I can copy file to flash? The serial number is beginning from FDO2118.
Danny
Thank for your help. I had already contacted TAC, and was told to provide information for RMA.
Danny
Leo Laohoo
Console into the switch and post the entire boot-up process.
