Pair of Cisco 9k as Primary and Secondary Root
Barry Landon
We have two Cisco 9k running as our cores.  They run as a pair, if one goes down the other takes over.  We have around 20 vlans all seeing as Cisco 9K SW1 as root.  Can i add secondary root command to Cisco 9K SW2 baring in mind they are both seen as one whole switch. The root primary commands only appears on Cisco 9K SW1.
6 Replies 6
balaji.bandi
Cisco 9K ( is this catalyst 9K - what model ?) or Nexus 9K ?
is this stacked or stackwise virtual ?  root in terms of Spanning treed ?
you can add higher value than in the Primary so other switch become secondary of the primary go down.
example :
Primary vlan priority 4K
Secondary  vlan priority 8K
BB
Thanks for the quick response.  The switches a stackwise virtual.  We have mirrored vpcs running on each. OK so from what your saying i can add the Cisco 9K sw2 as secondary root.
You still not confirmed the Model of the Devices ?
The switches a stackwise virtual.  - If this stack wise virtual  ( Physically 2, but logically 1 only ) - You do not need to configure spanning tree seconday (not you get option to change anything on the passive device)
this confusiing to me ( is this nexus ?)
BB
The deice is a Nexus C93180YC-EX.  The device is stacked and not stackwise virtual.
 Nexus C93180YC-EX.
Nexus work in different way (nor it stacked or SWV)  - they work as vPC in teh domain
You can make priorties as suggested for spanning tree ( if required) - most case you do not need.)
BB
Hello
if they are logically stacked - vss-vpc-stackwise then the stp root priority should be the same
What stp mode are you running?
Kind Regards
Paul
