Catalyst 3850 NSF and ISPF
oguarisco
Level 3
Level 3
Hello all,
we're configuring OSPF in a stack of Cat3850 which is in SSO mode enabling NSF.
I would like to enable also the ISPF feature but I have not found information on CCO about Cat3850 and this feature... as it is with Cat4500X.
Is the ISPF feature supported on Cat3850?
BR
Omar Guarisco
10 Replies 10
Julio E. Moisa
I recommend this tool, you will see if your IOS or model supports this OSPF feature, search ispf as Incremental
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
thanks a lot for the info... yes I remember this tools but is not always updated, in fact not all Releases (i.e. IOS XE) are present.
Omar
Good to know, are you using IP services IOS or is it IP Base?
IP Services the latest train
I found ispf for IS-IS protocol on 3850 but not for OSPF:
http://www.cisco.com/c/en/us/support/ios-nx-os-software/ios-xe-3e/products-installation-and-configuration-guides-list.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/37e/consolidated_guide/b_37e_consolidated_3850_cg/b_37e_consolidated_3850_cg_chapter_0110110.html#d463329e6983a1635
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_isis/configuration/xe-3se/3850/irs-xe-3se-3850-book/irs-fscpc.html
Thanks a lot!!!
I'll try in labo
Omar
You are welcome
Joseph W. Doherty
Have you tried to enable it on your 3850?
next week in labo... and I will let you know if it works with XE 3.7.5
