port-channel doubt
Arjun Dabol
SW1                                                    SW2
                  1-------------------------1
                  2-------------------------2
                  3-------------------------
If I have 2 switch and between them we have 3 links. If we create port-channel on SW1 including all 3 links BUT on SW2 we create Port channel using only 2 Links, will it work ? what problem we may face ?
thanks
Abhishek
6 Replies 6
Dennis Mink
That seems like a pointless exercise to me, the port channel will not negotiate the 3 links aggregated as far as I can see or you will have 2 links aggregated because port 3 on sw2 will not respond to LACP.  could you explain what it is you are after or trying to achieve.
Please remember to rate useful posts, by clicking on the stars below.
thx all , Just wanted to understand the concept here of such design and you all helped in that. thanks again
It was a pleasure Arjun,
Have a great day!
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
azibnaseem
Hey @arjun dabol,
minkdennis  is right that etherchannel wouldn't form. You have to make identical ports on both switches in order to etherchannel to work.
Regards'
azibnaseem
Hey adaveadmin
I have created a topology on GNS3 & make an identical settings as per your requirement. Using GNS3 etherchannel link has been formed & showing up on both switches. Please try to configure on real switches & see the outputs using debug etherchannel all command. If etherchannel is negotiated it may cause the load balancing & performance issues.
Regards'
Julio E. Moisa
Hi Arjun,
If you create the port channel with 3 ports on switch 1 but on switch 2 you will use only 2 ports to create the port channel, it will work but using only 2 ports:
Please check the following configuration:
Switch 1
SW1#show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
12 Po12(SU) LACP Fa1/0/27(P) Fa1/0/28(P) Fa1/0/29(I)
Port-channel12         unassigned      YES unset  up                    up
Switch 2
SW2#sh etherchannel summary
d - default port
12 Po12(SU) LACP Fa1/0/7(P) Fa1/0/8(P)
The bundle will be created with 2 ports only, the third will be as stand alone, now if you want to use 3 links in a future on both switches, take in consideration that the loadbalance will not be equal, please visit the following link:
https://www.packetmischief.ca/2012/07/24/doing-etherchannel-over-3-5-6-and-7-link-bundles/
Now with 3 links, everything works:
SW1#SH ETHErchannel SUMmary
d - default port
12 Po12(SU) LACP Fa1/0/27(P) Fa1/0/28(P) Fa1/0/29(P)
SW2#SH ETHERchannel SUMmary
d - default port
12 Po12(SU) LACP Fa1/0/7(P) Fa1/0/8(P) Fa1/0/9(P)
Please rate the comment if it is useful.
