Showing results forĀ
Search instead forĀ
Did you mean:Ā
Catalyst 3850 rack mount kit: 3850-RACK-KIT or C3850-4PT-KIT ?
richard_artes
When purchasing a Cisco Catalyst 3850, do we need to buy the rack mounting kit to install it in  a standard 19" rack? 3850-RACK-KIT or C3850-4PT-KIT ? Is the 4-point kit really necessary, can the 3850 hang only on the front of the rack?
Reza Sharifi
No, you don't need the C3850-4PT-KIT.  3850-RACK-KIT comes in the box and it is good enough as long as you rack it nice and tide. The reason some people use C3850-4PT-KIT is because the switch will hang from the back a little when using 3850-RACK-KIT and so if you don't like that than you want the 4PT.
Reza Sharifi
Thanks Reza, good to know. Richard.
What is the max rack depth when mounting the switch (C3850) using the rails C3850-4PT-KIT?
