Catalyst 4500-E show temperature output
gbressanin
I'm not able to find in any documents what "remote" means . What's the difference in the following output  between the row with and without "remote"?.
Can someone help me ??
sh environment temperature
Module Sensor                     Temperature          Status
1      Air inlet                  38C (56C,68C,71C)              ok
1      Air inlet remote           30C (46C,59C,62C)              ok
1      Air outlet                 40C (66C,76C,79C)              ok
1      Air outlet remote          35C (60C,71C,74C)              ok
2      Air inlet                  37C (56C,68C,71C)              ok
2      Air inlet remote           30C (46C,59C,62C)              ok
2      Air outlet                 38C (66C,76C,79C)              ok
2      Air outlet remote          34C (60C,71C,74C)              ok
3      XPP                        39C (52C,64C,67C)              ok
3      XPP Remote                 47C (61C,75C,78C)              ok
3      IFE                        36C (56C,68C,71C)              ok
3      IFE Remote                 42C (61C,74C,77C)              ok
3      CPU                        34C (47C,61C,64C)              ok
3      CPU Remote                 42C (61C,77C,80C)              ok
4      XPP                        39C (52C,64C,67C)              ok
4      XPP Remote                 47C (61C,75C,78C)              ok
4      IFE                        35C (56C,68C,71C)              ok
4      IFE Remote                 42C (61C,74C,77C)              ok
4      CPU                        34C (47C,61C,64C)              ok
4      CPU Remote                 44C (61C,77C,80C)              ok
Thanks in advance
Giovanni
Rino Salerno
we've had the same problem too on a "Supervisor 7L - E" w/ IOS 15 in a client production environment:
     x      CPU                        34C (47C,61C,64C)              ok
     x      CPU Remote           62C (61C,77C,80C)              warning
We'd like to know what this 'CPU Remote' and its values do mean.
Thank you in advance,
     Best regards.
