09-16-2010 07:29 AM - edited 03-06-2019 01:00 PM
Can someone tell me how to setup a SPAN (mirror) session on a 4507? Everything I read/understand is the command should be set span while in enable mode. This does not appear to be the case for our 4507 running cat4500-entservicesk9-mz.122-40.SG.bin
I am trying to find out why our messenger program keeps dropping.
Thank You,
Solved! Go to Solution.
09-16-2010 07:32 AM
Thank You,
"set span" is CatOS terminology. You are using IOS so the commands are different. See this link for configuration details -
Jon
09-16-2010 07:32 AM
Thank You,
Jon
09-16-2010 07:39 AM
Yeah, i just noticed that as you replied.. So i was trying to change the title of this post....
Thanks for the post.. Hopefully i will not have to ask another question !!!
