Catalyst 4510r+e keeps booting into ROMmon
PeyLawro
Afternoon all,
We have a Catalyst 4510r+e that in November we was going to tweak the config so we can use at another site, which at the time booted up fine as we tested this as it has been sat there for a good few years (before my time here).... a few months later this now doesn't happen and it boots into ROMmon.
we never changed anything when testing in November that we are sure of.
here is what putty is spitting out at me when using console cable
Rommon signature verification PASSED for golden image
Rommon signature verification PASSED for primary image
FPGA signature verification PASSED for primary image
* Welcome to Rom Monitor for WS-X45-SUP7-E System. *
* Copyright (c) 2008-2011 by Cisco Systems, Inc. *
* All rights reserved. *
Primary Rom Monitor Version 15.0(1r)SG5
CPU Rev: 2.2, Board Rev: 10, Board Type: 101, CPLD Moka Rev: 7.0x3718.0xb565
Chassis: WS-C4510R+E
Got Mac Address: 44:d3:ca:**:**:**
MAC Address : 44-d3-ca-**-**-**
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Peer supervisor not detected or is not running IOS
Supervisor uplinks and all linecards have been reset
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- flashboot:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin
Invalid filename flashboot:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin. It must begin with device name.
Type 'boot -help' for details.
The switch will automatically reboot now...
rommon 1 >
Got Mac Address: 44:d3:ca:**-**-**
Netmask : Not set.
Gateway : Not set.
Autoboot cancelled......... please wait!!!
rommon 1 > [interrupt]
usage: dir { [ bootflash: ] | [ slot0: ] | [ usb0: ] }
rommon 3 >dir bootflash:
Date Time Attribute Size Name
2013/01/30 01:40 -rw-rw-rw- 1144 FOX1502G9AA_201301290916112610.lic
2014/01/27 10:20 -rw-rw-rw- 88077704 cat4500e-universal.SPA.03.02.08.SG.150-2.SG8.bin
Total space = 808548 KB
Available = 725840 KB
rommon 6 >boot bootflash: 4500e-universal.SPA.02.03.08.SG.150-2.SG8.bin
loading image
Checking digital signature
bootflash:/cat4500e-universal.SPA.03.02.08.SG.150-2.SG8.bin: Digitally Signed Release Software with key version A
Rommon reg: 0x00004F80
Reset2Reg: 0x00000F00
Image load status: 0x00000000
Snowtrooper 220 controller 0x042F2975..0x0447E526 Size:0x0056CB6D Program Done!
Linux version 2.6.24.4.56.24.k10 (majoshi2@build-lnx-036) (gcc version 4.2.1 p1 (Cisco c4.2.1-p1)) #1 SMP Mon Dec 2 19:14:25 PST 2013
Starting System Services
diagsk10-post version 5.0.3
prod: WS-X45-SUP7-E part: 73-14393-02 serial: CAT1646L332
Power-on-self-test for Module 5: WS-X45-SUP7-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
post done
Exiting to ios...
Starting IOS Services
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.02.08.SG RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 02-Dec-13 18:32 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x100A1F54, data-base: 0x13D7BE40
cisco WS-C4510R+E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FOX1502G9AA
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
1 Virtual Ethernet interface
288 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Press RETURN to get started!
*Mar 13 05:34:09.452: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'ipbase'
*Mar 13 05:34:09.516: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Mar 13 05:35:20.790: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-X4748-RJ45-E S/N: CAT1640L49T Hw: 1.1) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 2 (WS-X4748-RJ45-E S/N: CAT1640L5J4 Hw: 1.1) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4748-RJ45-E S/N: CAT1640L5FT Hw: 1.1) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X4748-RJ45V+E S/N: CAT1640L5TB Hw: 1.3) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 5 (WS-X45-SUP7-E S/N: CAT1646L332 Hw: 2.1) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 7 (WS-X4748-RJ45-E S/N: CAT1640L5LE Hw: 1.1) is online
*Mar 13 05:35:21.763: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 10 (WS-X4748-RJ45-E S/N: CAT1640L5L4 Hw: 1.1) is online
*Mar 13 05:35:25.780: %SW_VLAN-6-VTP_DOMAIN_NAME_CHG: VTP domain name changed to ****.
*Mar 13 05:35:25.928: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 13 05:35:26.062: %SYS-5-RESTART: System restarted --
CHO_Core_1>en
Password:
CHO_Core_1#dir all
Directory of bootflash:/
73763 -rw- 1144 Jan 30 2013 01:40:26 +00:00 FOX1502G9AA_201301290916112610.lic
73764 -rw- 88077704 Jan 27 2014 10:20:26 +00:00 cat4500e-universal.SPA.03.02.08.SG.150-2.SG8.bin
831541248 bytes total (743260160 bytes free)
Directory of crashinfo:/
9922 -rw- 0 Nov 18 2012 12:43:55 +00:00 koops.dat
141433856 bytes total (139310080 bytes free)
Directory of kinfo:/
37 -rwx 1354 Jan 7 2000 07:12:46 +00:00 kinfo_20000107-071247-UTC
38 -rwx 256 Feb 5 2000 06:19:22 +00:00 last_kinfo
39 -rwx 1369 Feb 5 2000 06:19:22 +00:00 kinfo_20000205-061922-UTC
16915456 bytes total (16657408 bytes free)
Directory of system:/
2 -r-- 0 <no date> default-running-config
4 dr-x 0 <no date> memory
1 -rw- 11788 <no date> running-config
3 dr-x 0 <no date> vfiles
No space information available
Directory of tmpsys:/
6 drw- 0 <no date> eem_lib_system
5 drw- 0 <no date> eem_lib_user
24 -rw- 0 <no date> eem_pnt_0
26 -rw- 0 <no date> eem_pnt_1
44 -rw- 0 <no date> eem_pnt_10
46 -rw- 0 <no date> eem_pnt_11
48 -rw- 0 <no date> eem_pnt_12
50 -rw- 0 <no date> eem_pnt_13
52 -rw- 0 <no date> eem_pnt_14
54 -rw- 0 <no date> eem_pnt_15
28 -rw- 0 <no date> eem_pnt_2
30 -rw- 0 <no date> eem_pnt_3
32 -rw- 0 <no date> eem_pnt_4
34 -rw- 0 <no date> eem_pnt_5
36 -rw- 0 <no date> eem_pnt_6
38 -rw- 0 <no date> eem_pnt_7
40 -rw- 0 <no date> eem_pnt_8
42 -rw- 0 <no date> eem_pnt_9
4 drw- 0 <no date> eem_policy
8 drw- 0 <no date> eem_pub
23 -rw- 0 <no date> eem_rpc_0
25 -rw- 0 <no date> eem_rpc_1
43 -rw- 0 <no date> eem_rpc_10
45 -rw- 0 <no date> eem_rpc_11
47 -rw- 0 <no date> eem_rpc_12
49 -rw- 0 <no date> eem_rpc_13
51 -rw- 0 <no date> eem_rpc_14
53 -rw- 0 <no date> eem_rpc_15
27 -rw- 0 <no date> eem_rpc_2
29 -rw- 0 <no date> eem_rpc_3
31 -rw- 0 <no date> eem_rpc_4
33 -rw- 0 <no date> eem_rpc_5
35 -rw- 0 <no date> eem_rpc_6
37 -rw- 0 <no date> eem_rpc_7
39 -rw- 0 <no date> eem_rpc_8
41 -rw- 0 <no date> eem_rpc_9
7 drw- 0 <no date> eem_temp
1 dr-x 0 <no date> lib
9 drw- 0 <no date> macro_scripts
Directory of cat4000_flash:/
1 -rw- 616 <no date> vlan.dat
524284 bytes total (523668 bytes free)
Directory of nvram:/
512 -rw- 2758 <no date> startup-config
513 ---- 5 <no date> private-config
514 -rw- 2758 <no date> underlying-config
1 ---- 0 <no date> rf_cold_starts
2 -rw- 1058 <no date> cpu_threshold_trap.eci
4 -rw- 1528 <no date> license_trap.eci
6 -rw- 886 <no date> memory_trap.eci
7 -rw- 858 <no date> rf_trap.eci
8 -rw- 108 <no date> ma_trap_keyword
9 ---- 88 <no date> persistent-data
10 -rw- 0 <no date> ifIndex-table.gz
11 -rw- 17 <no date> ecfm_ieee_mib
524284 bytes total (510205 bytes free)
CHO_Core_1#show bootvar
BOOT variable = flashboot:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
CHO_Core_1#
Nothing is jumping out at me and let me clarify.... i'm very new to this role and its my first proper role in IT so still getting my head around a vast number of things.
appreciate any help
marce1000
 >...Current BOOT file is --- flashboot:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin
       - It looks like an incorrect image is specified for booting , this flashboot string should probably on refer to flash: or bootflash:
 M.
marce1000
 M.
Thanks for that @marce1000
Will check it in the morning when back on site and let you know how i get on.
Leo Laohoo
The boot variable string is configured with the wrong syntax.
conf t
 no boot system flash flashboot:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin
 boot system flash bootflash:cat4500e.SPA.03.02.08.SG.150-2.SG8.bin
end
wr
