Catalyst 4900m with TwinGigi Converter
jayshihlin
Hello all,
Got a question for 4900m with TwinGigi Converter.
I bought couple TwinGigi Convert thinking to use it on fix module ports (8 * 10G ports on 4900m ten1/1 to 1/8).  I follow TwinGigi configuration guide http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/sw_int.html#wp1077316 however, I am getting Invalid commands on hw-module:  Thanks in advanced!!!
Switch(config)#hw-module module 1 ?
  logging  Logging
Switch(config)#hw-module module 2 ?
  logging  Logging
  power    Enable/disable power to module in specified slot
Switch(config)#hw-module module 3 ?
  logging  Logging
here is show ver and show mod:
Switch#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Vers
ion 15.0(2)SG2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 07-Dec-11 20:20 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12CF5BC8
ROM: 12.2(44r)SG10
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.79
Switch uptime is 6 hours, 14 minutes
System image file is "bootflash:cat4500e-ipbasek9-mz.150-2.SG2.bin"
--More--
*May 24 18:07:33.150: %SYS-5-CONFIG_I: Configured from console b        e
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4900M (MPC8548) processor (revision 2) with 1048576K bytes of memory.
Processor board ID JAE161503L0
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
1 Virtual Ethernet interface
20 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switch#show mod
Chassis Type : WS-C4900M
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     8  4900M 10GE (X2)                        WS-C4900M          JAE161409U8
2    20  10/100/1000BaseT (RJ45)                WS-X4920-GB-RJ45   JAE161404RQ
M MAC addresses                    Hw  Fw           Sw               Status
1 5057.a8ab.6200 to 5057.a8ab.6207 1.8 12.2(44r)SG1 15.0(2)SG2       Ok
2 649e.f3b0.f79c to 649e.f3b0.f7af 1.2                               Ok
Switch#
Thanks!
JL
Ivan Shirshin
The TwinGig converter module is supported with Cat4900M for the WS-X4908-10GE half card only, not for the base X2 ports, as TwinGig requires additional port ASIC which is not on baseboard.
Please see the data sheet (table 1) at:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Kind Regards,
Ivan
Kind Regards,
Ivan
