catalyst 500 express switch , how to discover ?
jillesmiedema
is there a discover tool for such a switch, i forgot the assigned ip , i know very very stupid.
handoko wiyanto
Level 3
Level 3
- whats the user network segment of your switch?
- do you implement separate network management for all cisco devices? if yes, whats this network segment?
perhaps if youre in a critical time, resetting the config will do:
http://www.cisco.com/en/US/products/ps6545/products_tech_note09186a0080707fb0.shtml
joaniesylvain
Hi jillesmiedema,
If you connect to the switch and use a packet sniffer such as wireshark you should be able to determine the ip address by reading the info in the CDP packets (given that CDP hasn't been disabled).
