Catalyst 6500 15.1(2)SY syslog
afmiller1
Trying to get syslog running on this switch. Below is the output for the sh log command. I've turned logging on, and set the hosts. Also set trap to informational. The .125 has a Syslog up and running and isn't get any of the console login traps that should be sent. What am I missing?
logging host x.x.x.101
logging host x.x.x.125
Router#sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 82 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level informational, 18 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level informational, 63 message lines logged
Logging to x.x.x.101 (udp port 514, audit disabled,
link up),
24 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging to x.x.x.125 (udp port 514, audit disabled,
link up),
21 message lines logged,
filtering disabled
Logging Source-Interface: VRF Name:
Log Buffer (8192 bytes):
afmiller1
Fixed..
Please, describe what you did and then you can help others.
Thank you.
