Catalyst 6500 Input Errors
ursshared
Community Member
A port connected on my 6500 connected to a 3750 has lots of errors. Here is the output from a show interface:
GigabitEthernet1/7 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0011.938a.6032 (bia 0011.938a.6032)
Description: To SW560CRG Pri
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 241/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:55, output 00:00:51, output hang never
Last clearing of "show interface" counters 00:50:04
Input queue: 0/2000/23107/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 751000 bits/sec, 113 packets/sec
5 minute output rate 300000 bits/sec, 152 packets/sec
255165 packets input, 147281086 bytes, 0 no buffer
Received 926 broadcasts (758 multicasts)
439 runts, 0 giants, 0 throttles
23107 input errors, 10546 CRC, 11002 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
430012 packets output, 120890205 bytes, 0 underruns
Any idea where to start? The 3750 does not show any errors on its side of the trunk, just the 6500.
lamav
Level 11
Level 11
Before reinventing the wheel, I would recommend checking speed and duplex settings on both ends and making sure they match.
Then try replacing cable.
Come back and let us know what happens.
Victor
