03-20-2012 03:32 AM - edited 03-07-2019 05:40 AM
I've a question about Etherchannel on 10G interface
On the same 6509 (without VSS), I like to use modules as :8-Port 10 Gigabit Ethernet Fiber Module
Can we configure several interfaces (10G) in Etherchannel between two modules ?
i.e : Module 3 and Module 4, Port 1 of each module configured as Etherchannel between them, same for Port 2 between, etc ...
At the End of the links, can I use a cisco equipment other than the 65xx ?
Do we have any others limitation ?
Thx for you feedback on this
Philippe.
Solved! Go to Solution.
03-20-2012 10:48 AM
There is no issue using interfaces from different line cards within the same chassis to create Etherchannels. It could 8 port 10 gig, 16 port 10 gig, etc.. As long as speed and duplex is the same, no problems.
03-21-2012 08:47 AM
03-21-2012 11:08 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
re: other limitations
If you really need 8 ports of 10 gig, keep in mind bandwidth limitations of the different line cards. Also, for that much bandwidth, you might want to consider the sup2t with optionally the new 40 gig ports.
PS:
BTW, I've worked in an environment that used/uses 8x10gig Etherchannel. (I've also seen 8x10gig drop packets because of too much traffic.)
03-20-2012 10:48 AM
03-21-2012 02:22 AM
Thank you very much for your answer.
Again one please, do you know the number of ports than we can "put" in the Etherchannel ?
Philippe.
03-21-2012 08:47 AM
Hi Philippe,
The maximum is 8.
03-21-2012 11:08 AM
Disclaimer
Posting
PS:
