Catalyst 6500
abbas.ali
Level 6
Level 6
Is basic routing possible with Supervisor I engine in Catalyst 6500 series multilayer switches
Jon Marshall
Do you have an MSFC card on the Supervisor ?
Jon
ankbhasi
Hi Abbas,
If your sup 1 has msfc daughter card installed on it then yes it is possible but if it is only a sup engine then it is not capable of any routing.
Ankur
*Pls rate all helpfull post
