Catalyst 6506 vlan-based qos configuration
Eugene Khabarov
Level 7
Level 7
Hi All!
I was unable to configure vlan-based qos on
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXH6, RELEASE SOFTWARE (fc1)
Seems to me my configuration is not working. Here is the output of the interface:
sh int G1/6 | i rate
  Queueing strategy: fifo
  30 second input rate 25231000 bits/sec, 4282 packets/sec
  30 second output rate 46940000 bits/sec, 9257 packets/sec
And here is my configuration:
interface Vlan3
ip address 192.168.1.1 255.255.252.0
service-policy input TEST_IN_PMAP
service-policy output TEST_OUT_PMAP
interface GigabitEthernet1/6
switchport
switchport access vlan 3
load-interval 30
mls qos vlan-based
mls qos trust dscp
#sh class-map
Class Map match-any class-default (id 0)
   Match any
Class Map match-all TEST_IN_CMAP (id 2)
   Match access-group  119
Class Map match-all TEST_OUT_CMAP (id 1)
   Match access-group  118
#sh policy-map
  Policy Map TEST_IN_PMAP
    Class TEST_IN_CMAP
     police cir 30000000 bc 937500
       conform-action transmit
       exceed-action drop
  Policy Map TEST_OUT_PMAP
    Class TEST_OUT_CMAP
       exceed-action drop
#sh ip access-lists 118
Extended IP access list 118
    30 permit ip any host 192.168.1.168
#sh ip access-lists 119
Extended IP access list 119
    30 permit ip host 192.168.1.168 any
The questions are:
Why I can't see matches in ACLs? I've double checked the direction and seems to me it is correct. I can't see matches even I configure something like this:
10 permit ip host 192.168.1.168 any
20 permit ip any host 192.168.1.168
Why my output rate is higher than 30M? Is it bacause there is no matching traffic here in ACLs?
I'm absolutely shure that this host with such ip connected to this interface:
#sh arp | i 192.168.1.168
Internet  192.168.1.168           0   feed.beef.f00d  ARPA   Vlan3
#sh mac address-table |  i feed.beef.f00d
*    3  feed.beef.f00d   dynamic  Yes          0   Gi1/6
In your current design, how much traffic is leaving Vlan3 and how much traffic is remaining within Vlan3?
Only traffic leaving Vlan3 will be policed. Intra-Vlan traffic won't be policed.
Edison
9 Replies 9
Edison Ortiz
Post the output from
show mls qos
and
show mls qos ip g1/6
Hi! Thank you for reply. Here is output:
#sh mls qos
  QoS is enabled globally
  Policy marking depends on port_trust
  QoS ip packet dscp rewrite enabled globally
  Input mode for GRE Tunnel is Pipe mode
  Input mode for MPLS is Pipe mode
  QoS is vlan-based on the following interfaces:
    Gi1/6
QoS Trust state is CoS on the following interface:
Gi2/27
QoS Trust state is DSCP on the following interface:
Gi1/1 Gi1/2 Gi1/3 Gi1/4 Gi1/5 Gi1/6 Gi1/7 Gi1/9 Gi1/10 Gi1/11
Gi1/12 Gi1/13 Gi1/14 Gi1/15 Gi1/16 Gi1/17 Gi1/18 Gi1/19 Gi1/20 Gi1/21
Gi1/22 Gi1/23 Gi1/24 Gi1/25 Gi1/26 Gi1/27 Gi1/28 Gi1/29 Gi1/30 Gi1/32
Gi1/33 Gi1/34 Gi1/35 Gi1/37 Gi1/38 Gi1/39 Gi1/40 Gi1/41 Gi1/42 Gi1/47
Gi1/48 Gi2/5 Gi2/6 Gi2/7 Gi2/8 Gi2/9 Gi2/10 Gi2/11 Gi2/12 Gi2/13
Gi2/14 Gi2/15 Gi2/16 Gi2/17 Gi2/18 Gi2/19 Gi2/21 Gi2/22 Gi2/23 Gi2/24
Gi2/25 Gi2/26 Gi2/33 Gi2/35 Gi2/36 Gi2/37 Gi2/38 Gi2/39 Gi2/40 Gi2/41
Gi2/43 Gi2/45 Gi2/46 Gi2/48
  Vlan or Portchannel(Multi-Earl) policies supported: Yes
  Egress policies supported: Yes
----- Module [3] -----
  QoS global counters:
    Total packets: 21897742423
    IP shortcut packets: 0
    Packets dropped by policing: 0
    IP packets with TOS changed by policing: 486575146
    IP packets with COS changed by policing: 2
    Non-IP packets with COS changed by policing: 0
    MPLS packets with EXP changed by policing: 0
----- Module [4] -----
    Total packets: 533654
    IP packets with TOS changed by policing: 2
----- Module [5] -----
    Total packets: 3557578797757
    Packets dropped by policing: 12390896
    IP packets with COS changed by policing: 69251809858
#sh mls qos ip G1/6
   [In] Default.   [Out] Default.
QoS Summary [IPv4]:      (* - shared aggregates, Mod - switch module)
          Int Mod Dir  Class-map DSCP  Agg  Trust Fl   AgForward-By   AgPoliced-By
                                       Id         Id
         Gi1/6  5  In    Default    0    0*    No  0   426590389744              0
That interface is associated to the Supervisor PFC (Module 5) and if you see the MLS QOS counters on module 5, packets were dropped by policing.
The mls qos ip output also indicates the 'direction' which is inbound.
Your inbound counter does not exceed 30Mbps.
I believe your outbound ACL needs some work. Can you try any/any on the outbound and see if the policer takes effect?
Also, you won't get matches on ACL since this is done in hardware.
I think "any any" is not good idea since there is many servers operational. Maybe I can lower the policing rate and try it on another server?
According to the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1547950
"Note that PFC QoS performs egress policing decisions at the ingress interface, on the PFC or ingress DFC"
Hi, Edison. Thank you for reply, but I don't understand your post. Sorry. Can you please rephrase? Do you mean that incoming traffic to the 192.168.1.168 should flow througth another physical inerface in vlan 3 to be matched by policer? So what about traffic coming from another vlan to this host?
Edison
I did some testing here with a couple of 6500s ...
Configure Vlan 100 on both and assigned 192.168.100.0/24 to their respective SVIs.
Initiate a ping with large packets from one box and applied mls qos vlan-based on the other box.
Before the policer the ping was not dropping...
Once I applied a policer, the interface througput on the policed device dropped and the the device doing the ping was getting drops:
Here are some verification outputs:
show mls qos ip ingress
                                       Id         Id
         Vl100  6  In   CISCO-IN    0    3   dscp  0          73736          18652
           All  6   -    Default    0    0*    No  0    21114275690              0
                                       Id         Id
         Vl100  6  In   CISCO-IN    0    3   dscp  0         998546         248766
Notice how the ingress is incrementing.
While on egress:
show mls qos ip egress
                                       Id         Id
         Vl100  6 Out  CISCO-OUT    0    2     --  0       13383612        1737988
           All  6   -    Default    0    0*    No  0    21114466322              0
                                       Id         Id
         Vl100  6 Out  CISCO-OUT    0    2     --  0       13420480        1747314
           All  6   -    Default    0    0*    No  0    21114512516              0
_______________________________
Portion of the config:
ip access-list extended OUTBOUND
permit ip host 192.168.100.1 any
ip access-list extended INBOUND
permit ip any host 192.168.100.1
class-map match-all CISCO-OUT
  match access-group name OUTBOUND
class-map match-all CISCO-IN
  match access-group name INBOUND
policy-map CISCO-OUT
  class CISCO-OUT
   police 1000000
policy-map CISCO
  class CISCO-IN
   police 1000000
interface Vlan100
ip address 192.168.100.1 255.255.255.0
service-policy output CISCO-OUT
service-policy input CISCO
Oh, thank you, Edison! It make sense now.
