Catalyst 6509 Crashes ...
Nuno Moreira
Hello...
I would appreciate someone could give me some help, trying to understand what is going on with Catalyst 6509 core switch...
From time to time (mainly on Mondays) the switch unexpectedly reloads letting me without any clue on the problem that is causing this malfunction.
Since I don’t usually work with Cisco Catalyst 6500 Series Switches, I’m a little unfamiliarized with these switches debug and troubleshooting.
Here’s the output from show version
CATALYST6500SW#show version
IOS (tm) s3223_rp Software (s3223_rp-IPSERVICESK9_WAN-VM), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 04:55 by kellythw
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR:
CATALYST6500SW uptime is 2 hours, 18 minutes
Time since CATALYST6500SW switched to active is 2 hours, 18 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 10:14:36 PORTUGAL-Summer Mon Apr 2 2012
System image file is "sup-bootdisk:s3223-ipservicesk9_wan-vz.122-18.SXF7.bin"
This product contains cryptographic …
cisco WS-C6509-E (R7000) processor (revision 1.2) with 491520K/32768K bytes of memory.
Processor board ID SMG1045N3J5
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
4 Virtual Ethernet/IEEE 802.3 interfaces
119 Gigabit Ethernet/IEEE 802.3 interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Where can I go from here?
Thanks and regards
replace of Supervisor Engine...
7 Replies 7
Reza Sharifi
If you have a Syslog server configured, you may able to find something point to an issue.  Also, your IOS is pretty old, and this issue sounds like a bug in the IOS.  An upgrade may resolve your issue.
Leo Laohoo
See if you can find any "crashinfo" files/directory.  If you do, attach them to this thread.
Hello
Switch will not leave any crashinfo as it thinks that it was powered down by powering it off:
If you see this happening almostly on same time - then better to check environment of the sserver room and see what may cause the loss of power to the switch by that time. Possibly worth changing the power source. And then further consider PS problem or power convertor problem on sup. Though it is worth to check power source first.
Hope this helps,
Nik
HTH,
Niko
jamiegrive
Maybe cleaner comes in on a Monday and unplugs it so they can use the socket for a vacuum? Lol...
Yep, maybe she stole someone’s finger to get inside the room... LOL
Ok, so we replaced the SUP and it seems to be working ok... ( for now... )
thanks you guys...
