Catalyst 6509 VSS dual-active recovery
guy.richard
I'm using 2 6509 in VSS (version s72033-ipbasek9-mz.122-33.SXI2a.bin)
EV-SRGI1&2-6509-1#sh switch virtual role
Switch  Switch Status  Preempt    Priority  Role     Session ID
        Number         Oper(Conf) Oper(Conf)         Local  Remote
LOCAL    1     UP      FALSE(N )   110(110)  ACTIVE   0      0
REMOTE   2     UP      FALSE(N )   100(100)  STANDBY  2298   6693
In dual-active recovery mode: No
EV-SRGI1&2-6509-1#sh switch virtual dual-active fast-hello
Fast-hello dual-active detection enabled: Yes
Fast-hello dual-active interfaces:
Port       Local State    Peer Port    Remote State
Gi1/5/3    Link up        Gi2/5/3      Link up
Dual-active recovery mode works well except when the Inter-VSS link become operational again, the "recovery switch" never reloads to "stanby" because it indicates configuration has been changed and I have to save it before reloading
Is this normal ?
Thanks for help
mmacdonald70
The configuration guide states that the failed switch will not automatically reboot if there has been a change to the config which has not been saved.  Did you perform a cop run sta since the last change?
