Catalyst 6513-E Module Placement
Mohamad Qayoom
Level 7
Level 7
I will soon replace a Catalyst 6509 switch with a Catalyst 6513-E switch. I was wondering what logic, if any, others use to place the modules in a chassis.
Here is the listing of the line cards that will go into the new switch.
WS-SUP720-3BSlot 1
WS-SUP720-3BSlot 2
WS-X6066-SLB-APCSlot 3
Slot 4
WS-SVC-SSL-1Slot 5
WS-SVC-SSL-1Slot 6
WS-X6148-GE-TXSlot 7
Slot 8
Slot 9
Slot 10
WS-X6066-SLB-APCSlot 11
WS-X6724-SFPSlot 12
WS-X6724-SFPSlot 13
Catalyst 6513-E
Mohamad
10 Replies 10
Wilson Samuel
Level 11
Level 11
Hi Mohamad,
Just curious, are you using total 4 Sup modules on a 6513 chasis or is it I am mistaken here?
regards
Sam Wilson
Good catch, Sam. It was the curse of copy and paste. I have updated the
post.
Mohamad
Check the following link. It states what slots the Sups should go into as well has the high performance line cards.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_qas09186a0080159963.html
     Thanks, Collin. I am not sure if this reference document is also for E series chasses. For example, the document mentions that for 6513, the supervisor modules should be in slot 7 and 8, but when I was configuring a Catalyst 6513-E I was allowed to use only slots 1 and 2 for supervisor engines.
Mohamad
There's another way to sort this.  You'll need a s_crew driver and a torch/flashlight.
The pins of the Supervisor engines and the line cards are totally different.  Check the chassis' back planes and you'll see two slots which have a different male pins and colors of the "board?".
Next time I'm going to the data center I'm bringing a torch, like Indiana Jones!
Also note in the above link-
            Slots 1-8 support a single fabric channel; slots 9-13 support dual fabric channels
Hey Collin,
Don't forget the whip and the pistol.
Mohamad Qayoom
Level 7
Level 7
Thanks, Leo.
I haven't bought the new chassis yet. I am sure the chassis will clearly be maked as to where the supervisor engines should go.
Mohamad
