Hello everybody,
the SuperVisor engine in slot 1 of a Catalyst 6513 needed to be replaced because a
hardware defect. The SuperVisor engine in slot 2 is active and running CatOS 8.5. The new
SuperVisor engine for slot 1 came with CatOS 6.3 and was not syncronized auromatically
after insertion. When the customer enter the command "Show boot" he get the output:
AG-A6513-51> (enable) sh boot
BOOT variable = bootflash:cat6000-sup2k8.8-5-5.bin,1;bootflash:cat6000-sup2k8.7-6-2.bin,1;
CONFIG_FILE variable =
ignore-config: disabled
auto-config: non-recurring, overwrite, sync disabled
ROMMON console baud: 9600
boot: image specified by the boot system commands
Image auto sync is disabled <--- !!!
Image auto sync timer is 120 seconds
I don't find a command to enable 'Image auto sync' or a command to initiate the
syncronization manually.
Can some help?
Every hint is welcome.
Thanks a lot!
Bye
Rene
