Catalyst 6880 - EXCESSIVE_PARITY_ERROR - how to reload a single linecard
Worker247
I get lots of EXCESSIVE_PARITY_ERROR - Messages on a 6880X running in a VSS.
Example:
Jul 29 13:04:56 10.15.1.239 361325: Jul 29 07:48:22.849: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 0: Parity error detected in VRAM
Jul 29 13:04:58 10.15.1.239 361326: Jul 29 07:48:24.381: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 0: Parity error detected in VRAM
Jul 29 13:05:01 10.15.1.239 361327: Jul 29 07:48:27.081: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 0: Parity error detected in VRAM
Jul 29 13:05:03 10.15.1.239 361328: Jul 29 07:48:30.837: %EARL-SW2_DFC1-3-NF_PARITY_ERROR: EARL 0  NF ASIC: Uncorrectable Parity error in Netflow
To get rid of the Messages a reload/reboot of the linecard is needed
https://quickview.cloudapps.cisco.com/quickview/bug/CSCus64795
Does "SW2_DFC1-1" mean SW2=Switch 2 and DFC1-1 = Slot 1?
Means SW2_DFC1-3 another linecard?
I would like to know with which commands I can reload the problematic linecards.
All best
Ca
As i understand
8 Replies 8
Leo Laohoo
Reseat the line card is far better than "reload the line card".
Pull out the line card, wait for 5 seconds, and push the line card back in.
... good to know. I will try to reseat the linecard as you proposed.
As the error Messages state "SW2_DFC1-1" for the parity errors
do I have to reseat the linecard in Switch2, Slot 1?
Hints "
EARL-SW2_DFC1-3-NF_PARITY_ERROR: EARL 0  NF ASIC: Uncorrectable Parity error in Netflow Table." to another Problem in another Slot?
All best
Ca
Yes, switch 2, slot 1.
Thanks for the info.
I reseat the card on sunday and report afterwards.
all best
Ca
Give the chassis 4 weeks. If the error message does not appear, then good.
If it does appear, move the line card from one slot to another: This will help determine if the issue is the line card or the back-plane of the chassis.
Hi Leo Laohoo,
I reseatet the Linecard as you proposed but somehow the linecard was not detected by the Chassis.
All port-LEDs of the linecard did not Flash at all so first i thaught I had to power the linecard up. So I typed:
(config)#power enable switch 2 module 1       which returned
% module is already enabled
Checking the ports gave back "Hardware not present"
After trying to reseat the card again, with the same outcome, I rebootet the whole Switch.
Now the linecard is back online and reacts normal.
I did not Encounter "EXCESSIVE_PARITY_ERRORS" to date.
Do you have an idea why the line card was not detected after reseat?
All best
Ca
Give the line card 4 weeks.
If no other logs appear, then all good.
If any other logs appear that is not "ordinary", RMA the line card.
To date all is ok.
Thanks for the answers.
all best
Ca
