Catalyst 9200 - SNMP ISSUE
MadyS
Hello everyone,
I am currently working on C9200 IOS-XE switches. I have to set up the SNMP service for supervision. I configured the service but there is no connection with the server that should receive the notifications. At first I thought the problem was related to the server but when I use the snmpwalk utility from the administration machine, I have the code Unknown user name.
Below is the configuration and results of the Show commands:
Site2_SW#sho snmp
Chassis: JAE24390QVT
100268 SNMP packets input
    0 Bad SNMP version errors
    0 Unknown community name
    0 Illegal operation for community name supplied
    0 Encoding errors
    0 Number of requested variables
    0 Number of altered variables
    0 Get-request PDUs
    0 Get-next PDUs
    0 Set-request PDUs
    0 Input queue packet drops (Maximum queue size 1000)
104841 SNMP packets output
    0 Too big errors (Maximum packet size 1500)
    0 No such name errors
    0 Bad values errors
    0 General errors
    0 Response PDUs
    4573 Trap PDUs
Packets currently in SNMP process input queue: 0
SNMP global trap: enabled
SNMP logging: enabled
    Logging to 10.42.3.2.162, 0/10, 4573 sent, 0 dropped.
SNMP Manager-role output packets
    0 Get-request PDUs
    0 Get-next PDUs
    0 Get-bulk PDUs
    0 Set-request PDUs
    4581 Inform-request PDUs
    4581 Timeouts
    0 Drops
SNMP Manager-role input packets
    0 Inform request PDUs
    0 Trap PDUs
    0 Response PDUs
    0 Responses with errors
SNMP informs: enabled
    Informs in flight 0/25 (current/max)
        4581 sent, 0 in-flight, 0 retries, 4581 failed, 0 dropped
Site2_SW#sho run | sect snmp
snmp-server engineID local 800000090300549FC68ED912
snmp-server engineID remote 10.42.3.2 1711111112
snmp-server group groupe_SITE2 v3 priv
snmp-server view Allmibs iso included
snmp-server view Allmibs private included
snmp-server view Allmibs mib-2 included
snmp-server view Allmibs ciscoMgmt.635 included
snmp-server trap-source Vlan30
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps flowmon
snmp-server enable traps entity-perf throughput-notif
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps eigrp
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps rep
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps license
snmp-server enable traps smart-license
snmp-server enable traps cpu threshold
snmp-server enable traps memory bufferpeak
snmp-server enable traps stackwise
snmp-server enable traps udld link-fail-rpt
snmp-server enable traps udld status-change
snmp-server enable traps fru-ctrl
snmp-server enable traps flash insertion removal lowspace
snmp-server enable traps energywise
snmp-server enable traps power-ethernet police
snmp-server enable traps envmon
snmp-server enable traps event-manager
snmp-server enable traps bfd
snmp-server enable traps dhcp
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps ipmulticast
snmp-server enable traps pimstdmib neighbor-loss invalid-register invalid-join-prune rp-mapping-change interface-election
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server enable traps errdisable
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server enable traps transceiver all
snmp-server enable traps rf
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps mac-notification change move threshold
snmp-server host 10.42.3.2 informs version 3 priv user_site2
snmp-server host 10.42.3.2 3  entity-state syslog
snmp-server host 10.42.3.2 version 3 priv user_site2
snmp-server inform retries 0
snmp ifmib ifindex persist
Site2_SW#sho snmp user
User name: user_site2
Engine ID: 1711111112
storage-type: nonvolatile     active
Authentication Protocol: SHA
Privacy Protocol: AES128
Group-name: groupe_Site2
Site2_SW#
Site2_SW#sho snmp eng
SITE2_SW#sho snmp engineID
Local SNMP engineID: 800000090300549FC68ED912
Remote Engine ID          IP-addr    Port
1711111112        remote      10.42.3.2   162
Site2_SW#
This is the configuration implemented on switch:
snmp-server group groupe_Site2 v3 priv
snmp-server user user_site2 groupe_Site2 remote 10.42.3.2 v3 auth sha S1te@_6_ROS priv aes 128 S1te@_6_CSK
snmp-server group groupe_Site2 v3 priv read Allmibs
snmp-server group groupe_ Site2 v3 priv
Can you please tell me if there is a particular parameter to activate on the 9000 series for it to work?
Thanks in advance !
Did you use this suyntax? Dont know if you delete information for security reasons.
snmp-server group <snmp group name> v3 auth
snmp-server user <snmp user name> <snmp group name> v3 auth md5 <auth password> priv des <priv password>
Your error message is quite clear. Your NMS can´t login in using that username
Thanks for yout reply, I used this syntax:
snmp-server group groupe_site2 v3 priv
snmp-server user user_site2 groupe_site2 remote 10.42.3.2 v3 auth sha password_sha priv aes 128 password_aes
Do you see the a problem in this configuration?
Well,  I dont.
 Using Cisco Prime I had to use cisco AES 256 but this is about encryption. Your message is related to user.
