Catalyst 9300L Scheduled Fast Reload
ZachOtt98645
I recently got to test the new fast reload feature of 17.x.x on the 9300L. Working at a 24/7/365 operation, minimizing downtime is critical. One caveat to this feature seems to be the inability to schedule a reload. In 16.x.x and before I would use
reload at 00:00 MON DD reason
to schedule a IOS upgrade. Does anyone know of a way to schedule a fast reload via a CLI command? (we don't use DNA Center in our environment yet) I'd prefer to not have to wake up at odd hours of the night to initiate one command and then go back to bed.
Thanks!
Reza Sharifi
See the config guide. Apparently reload fast is not used for software upgrades.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-3/configuration_guide/sys_mgmt/b_173_sys_mgmt_9300_cg/performing_extended_fast_software_upgrade.html
Honestly, if this is 24/7/365 operation, I would not want to be asleep when the switch reboot
You want to verify all is working before going back to sleep.
marce1000
 - Are there any additional options listed on (CLI)  reload fast (meaning the question-mark  should be part of the given-command).
 M.
As far as I can see (using 16.8.1 version), there is no other option after "reload fast"
 - Possible solution(s) could be to have an automated (python)-script , to remotely execute a command, triggered at a specific time, from linux-cron (e.g.) - Google with relevant keywords will provide examples.
 M.
