Catalyst 9k interface templates
munroe
Visitor
I'm investigating using interface templates to optimize our configurations.  However it seems like only a subset if interface commands are available to be applied via a template?  thinks like "ip verify source" and "ip arp inspection..." and "no cdp enable" are not available via the template.  Am I missing something or miss understanding what a template is for?
Interface Templates are a relatively new feature that was introduced with IOS-XE 16.7.1 if I remember correctly.
Today they cover a lot of routine stuff like STP, storm-control, DHCP snooping or port-based authentication with IBNS 2.0.
It is safe to assume that they will add more features with future releases but this will definitely take some time.
Leo Laohoo
Just want to know this is about Interface-level "template" and not interface "macro"?
Interface templates have been around since IOS 15.2 (maybe earlier?) and there has always been some commands that don't work and it varies between software versions and IOS/IOS-XE switches.
I currently have a template for IOS 15.2(7)Ex switches and a template for IOS-XE 16.12.x switches.  Both are based on what DNAC pushes for SDA.
!!! IOS 15.2(7)ex switches !!!
show template interface source user Port-Dot1x-Default-Voice-VLAN-Closed
Template Name       : Port-Dot1x-Default-Voice-VLAN-Closed
Template Definition :
 dot1x pae authenticator
 dot1x timeout tx-period 7
 dot1x max-reauth-req 3
 spanning-tree portfast edge
 switchport access vlan 999
 switchport mode access
 switchport nonegotiate
 switchport voice vlan 305
 mab
 access-session host-mode multi-domain
 access-session closed
 access-session port-control auto
 authentication periodic
 authentication timer reauthenticate server
 service-policy type control subscriber Dot1x-MAB-Guest-Default
 service-policy input IPPHONE+PC-BASIC
 ip dhcp snooping limit rate 100
 description ** Port for Endpoints with Voice VLAN dot1x closed**
 srr-queue bandwidth share 1 70 25 5
 srr-queue bandwidth shape  3 0 0 0
 priority-queue out
show run int gig 1/0/1
interface GigabitEthernet1/0/1
 ip arp inspection limit rate 100
 ipv6 nd raguard attach-policy host-policy
 ipv6 snooping attach-policy policy1
 ipv6 dhcp guard
 source template Port-Dot1x-Default-Voice-VLAN-Closed
sho derived-config interface gigabitEthernet 1/0/1
 ip access-group Auth-Default-ACL in
 priority-queue out
 ipv6 dhcp guard
 mab
!!! IOS-XE 16.12.x switches !!!
show template interface source user DefaultWiredDot1xClosedAuth
Template Name       : DefaultWiredDot1xClosedAuth
 dot1x timeout supp-timeout 7
 dot1x max-req 3
 switchport voice vlan 20
 mab
 service-policy output AutoQos-4.0-Output-Policy
 description ** Port for Endpoints with Voice VLAN dot1x closed **
show run interface GigabitEthernet 1/0/1
 device-tracking attach-policy IPDT_POLICY
 ip access-group IPV4_PRE_AUTH_ACL in
 ipv6 traffic-filter IPV6_PRE_AUTH_ACL in
 source template DefaultWiredDot1xClosedAuth
 spanning-tree bpduguard enable
 ip nbar protocol-discovery
show derived-config interface GigabitEthernet 1/0/1
 mab
 dot1x max-req 3
