11-06-2017 03:04 AM - edited 03-08-2019 12:38 PM
Hello everyone.
I couldn't find clear answer to these questions :
Can you tell me any rule about connecting Nexus and Catalyst switches together please?
I mean, is there any consideration or limitation ?
If you check Cisco website , you probably find both Nexus and Catalyst are introduced as core and data center switches.
Can you connect Nexus 9000 to catalyst 3850 ?( I know it's silly thing but can make it clear )
What does parent and child mean ? is it necessary to have parent and child ? I mean , can we use any switch as parent and child or they are specific models and must work with each other ?
Can you connect any Top Of Rack Nexus to any Core switch ( catalyst ) .
Thank you
Why cisco recommend both Nexus and Catalyst as core ? I taught nexus series are only for data center and can not be Core ( interconnect LAN-WAN-Datacenter together )
Solved! Go to Solution.
11-06-2017 04:07 AM
They work well together , ios side as standard po and nx-os side as vpc po , integrate mostly without issues
yes have it done currently we use 9k in and out of DC design as there very hardware powerful
can you provide the context here , there are multiple parent child setups like hierarchical qos or 7-5 -2 ks design , either way switches can be used as standalone anyway without any parent child scenario, but you cant use a fex alone as its a dumb switch gets its settings.info off the master either 5k or 7k depending on setup
yes that's not an issue
They were built for DC but are now regularly used in campus too , did they mean core DC and core campus or what exactly was specified in the doc you seen ? there is core 9k campus switches now too which are totally different than nexus 9ks
11-06-2017 05:27 AM
11-06-2017 04:07 AM
11-06-2017 05:27 AM
