Catalyst Block/Filtering CDP on ports
David Kondicz
Hi all,
is there any way to filter cdp throught acces ports on catalyst switches? We have virus on site which is searching for other devices throught CDP protocol or Mikrotic neighbour.
If i block - MAC Protocol 800 ,packet type Boadcast in mikrotik Bridge, i can stop the UBIQUITY Virus.
Bud how to stop them throught catalyst switches on FTTA - fiber to the antenna sites?
We are using catalyst 3560x,2960s.... Lan BASE
Thank you
dave
2 Accepted Solutions
Mark Malone
Can you not turn off cdp per port basis or globally no cdp enable/  no cdp run  until you remove thevirus
it uses 4224 TCP as well
To be honest never tried to block it like that , I seen the port on couple of websites as TCP 4224 bit it seems unofficial
Did you see this
if your device are Cisco switch you can apply mac access-list which will drop outgoing CDP packets , and because CDP use ARPA code 0x200 , mac access-list will contain : access-list 10 deny 0x2000
http://networkengineering.stackexchange.com/questions/8040/listen-only-stealth-cdp-on-ios
known port assignments and vulnerabilities
threat/application/port search:
 search
Port(s) Protocol Service Details Source
4224 tcp,udp applications A remote overflow exists in Xtell. The Xtelld daemon fails to perform proper bounds checking resulting in a buffer overflow. With a specially crafted request to port 4224, a remote attacker can cause arbitrary code execution resulting in a loss of integrity.
References: [BID-4193], [CVE-2002-0332]
SG
4224 tcp
Cisco CDP Cisco discovery Protocol (unofficial)
Mark Malone
Hi Mark,
i dont think that is tcp.
I dont want to disable cdp on port i want to filted and deny it throught port fog eg with acl in catalyst.
linke filter rule in Mikrotik : MAC Protocol 800 ,packet type Boadcast - Drop
Dave
Did you see this
 search
SG
4224 tcp
