catalyst switch model 2950 series need ios image flash is unable to load.
asgher555
 Hi, i'm in need of ios image for cisco 2950 series switch, because when its boots up its shows me a error message, Error loading "flash:c2950-i6q412-mz.121-13.EA1.bin"
Leo Laohoo
Post the output to the command:  dir flash:
when switch gets reload its show me this message.....
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 7739904
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
And that is all?  You don't see the prompt of "rommon1>"?
