Catalyst WS-C4507R+E show environment output shows XPP sensor status wanring
anil.gupta3
we were facing the high temperature issue with Cisco 4507 (physical temperature of the DC is around 19c). Since we were running the deffered IOS on the 4500, We have upgraded the ROMMON and IOS image of the Cisco 4507 switch. We have upgraded the ROMMON IOS image to latest 15.0(1r)SG11 version and main IOS image to stable & safe harbor 03.06.03.E (cat4500e-universal.SPA.03.06.03.E.152-2.E3.bin).
The current issue of high temperature is removed on all the module expect for module 3 & 4 on XPP sensor. Please help us to resolve the issue.
#sh environment
warning alarm: slot 3 has exceeded the warning temperature for 36h 24m 54s
warning alarm: slot 4 has exceeded the warning temperature for 36h 11m 26s
Module Sensor Temperature Status
1 air inlet 41C (45C,60C,70C) ok
1 air outlet 42C (61C,76C,86C) ok
2 air inlet 40C (45C,60C,70C) ok
2 air outlet 42C (61C,76C,86C) ok
3 XPP 49C (52C,64C,67C) warning
3 XPP Remote 66C (61C,75C,78C) warning
3 IFE 40C (56C,68C,71C) ok
3 IFE Remote 54C (61C,74C,77C) ok
3 CPU 35C (47C,61C,64C) ok
3 CPU Remote 40C (61C,77C,80C) ok
4 XPP 48C (52C,64C,67C) ok
4 XPP Remote 60C (61C,75C,78C) warning
4 IFE 41C (56C,68C,71C) ok
4 IFE Remote 53C (61C,74C,77C) ok
4 CPU 39C (47C,61C,64C) ok
4 CPU Remote 49C (61C,77C,80C) ok
5 air inlet 36C (45C,60C,70C) ok
5 air outlet 38C (61C,76C,86C) ok
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good good
PS2-1 220V good
PS2-2 220V good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Orange
Module 1 Status Led Color : Green PoE Led Color : Green
Module 2 Status Led Color : Green PoE Led Color : Green
Module 3 Status Led Color : Orange
Module 4 Status Led Color : Orange
Module 5 Status Led Color : Green PoE Led Color : Green
Fantray : Good
Fantray removal timeout : 93
Power consumed by Fantray : 165 Watts
I know this might sound silly! but there is nothing blocking the airflow round the chassis?
This could be due to some thing blocking the air flow to these module as Richard pointed out.
Please have a visual inspection around the chassis and ensure nothing blocks airflow. ALso ensure the emtpy slots have blank cover installed. If all these are ensured and still issue is seen, reseat the modules (I hope they are supervisors, if so reseat the standby first and check if it clears these issue, if so repeat the same for the other sup/card)
HTH,
Madhu
