Catalyst4503-E change register value but went power off register value change to defult
Hi All
           I have some problem on Catalyst4503-E :
I 'm config-register 0x2102 and show version output is "Configuration register is 0x2102" then i reloaded system can boot IOS normally but went i power off the chassis register value change back to defult "0x2101"
      Could you please help me to fix this issue
Leo Laohoo
Did you save the config after changing the config-register to 0x2102?
Yes. Use wr command to save it
The only thing that will over-ride that is a configuration item in the configuration itself.
