CBS-350 Port Speed Detection
BlueSkyy
Although not a problem, I've noted that on my CBS-350 the port speeds that are identified and published are 100Mbps, 1000Mbps and 10Gbps when interfaces to the SFP+ ports are being used.  This is the case when the attached device is running at 2.5Gbps, etc., or something less than 10Gbps but greater than 1000Mbps.
Is this normal operation or should the switch be reporting the actual negotiated port speed?
Web interface.  Thanks again!
@BlueSkyy
IOS switch I would expect to see the actuall speed but CBS-350 is different. Do you see this in command line or web interface?
mauryaanil154
Not working
