CBS250-8PP-D Incompatible with STP vs UTP?
Ed001
Upstream switch: Netgear GS324TP S350 v1.0.0.43 (latest release)
Downstream switch: CBS250-8PP-D v3.2.0.94 (latest release)
  • PoE is disabled on both switches (only enabled for the WAP ports on the Netgear)
  • Both switches set for auto-negotiate
  • All patch cables used for testing passed a wave test on my Fluke to Cat-6a
  • Power is via online /double-conversion UPS for both switches
  • "Wall Power" to each UPS is verified steady at 120 VAC 60Hz by Fluke and Klein meters
  • S350 and CBS250 have been configured to log to a syslog server
  • Horizontal (in-wall) cable is STP Cat-6a installed and tested by a BICSI certified technician /company
On initial install, the CBS250 went down "hard" as soon as the upstream port was plugged in with no logged errors by the S350.
I brought the switch back to my build bench for testing and found:
Whenever I connect from the S350 to the CBS250 using a shielded cable, the switch crashes and stays crashed.
  • No logs are sent when the CBS250 crashes by either device.  It's as if I disconnected power - no dying gasp or other diagnostic data.
  • The CBS250 crashed with both the "out of box" 3.1.1.7 firmware and after upgrade to 3.2.0.84 firmware
Whenever I connect from the S350 to the CBS250 using an unshielded cable, the switch boots and runs as expected.
I have tried shielded cables from 1m to 25m with the same crash-and-stay-crashed behavior.
I have tried unshielded cables from 1m to 15m with the same "runs just fine, no problems here" behavior.
When I connect to compute equipment (PC, Printer, IP Camera, etc.), the switch runs as expected with the same shielded cables that cause a crash when running switch-to-switch.
This happens with every port on the CBS250 and with Smartport enabled, disabled, or "hard set" for "Switch".
Any suggestions (other than running new UTP cable throughout my environment)?
this is very very strange situation. you better ask help form cisco TAC for find any OS related issues.
Good luck
KB
