CBS350-48P-4G switch noise management.
nealeeding
Hi guys,
I’m working to reduce fans noises in my home lab. I have had this Cisco switch for a while, and I am generally happy with it. But one thing that still bothers me is the sporadic fan noise it makes. Now, I have to say it only happens when ambient temperature rises above ~77F/25C, so it must be expected behavior, not a bug.
If you know, is there a way to control that behavior somewhere in GUI/CLI?
Or, what’s my option to go to quieter fan?
TIA.
DanielP211
Hello!
I can tell you it's definatly not a bug The fans get quite loud and it can be botersome. Option is to change them to quieter fans like MF40201V2-1000U-G99, you can buy them on digikey.
I know that people have tried changing them take a look at the following:
https://forums.servethehome.com/index.php?threads/cisco-sg350-series-fan-replacement.18880/
BR
****Kindly rate all useful posts*****
