06-08-2016 03:07 AM - edited 03-08-2019 06:07 AM
Hi!
I'm having a problem with an ISR4331 regarding NAT.
I cannot make a static nat for port 5011 because it keeps reponding this:
%Port 5011 is being used by system
The show ip socket gives me this:
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 255.255.255.255 68 192.168.1.254 67 0 0 2002211 0
17 10.16.214.7 514 192.168.1.254 64191 0 0 400210 0
And the show ip nat portblock dynamic global gives me this:
tcp:
8192 -9215 7168 -8191 6144 -7167 5120 -6143 4096 -5119
545 -617
udp:
8597 -9620 7573 -8596 6549 -7572 5525 -6548 4501 -5524
585 -648 512 -584
So, why can't i use the port 5011 ????
The ios is: 154-3.S5
Tkx
Miguel
06-08-2016 03:49 AM
Looks a lot like below on 4351 same type of IOS-XE software
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus49353/?referring_site=bugquickviewredir
| Product: |
(1)
| Known Affected Releases: |
(1)
06-08-2016 07:36 AM
I tried that workaround and it still gives me the same error.
06-08-2016 08:21 AM
Its definitely a bug as its on ASRs, 4000s and 7600s , the only other thing could recommend without going to TAC is upgrade to a safe harbour version like below images thats your best bet unless TAC have another workaround
https://software.cisco.com/download/release.html?mdfid=284358776&flowid=71902&softwareid=282046477&release=3.16.2S&relind=AVAILABLE&rellifecycle=ED&reltype=latest
The version your on doesn't look to be available anymore online which can indicate there were a lot of issues found with it and Cisco took it down
12-03-2016 10:34 PM
I have the same similar issue on 6500 too, on both
12.2-33.SXJ10
and
15.1-2.SYS8
ip nat inside source static udp 192.168.z.z 4500 a.b.c.d 4500 extendable
%Port 4500 is being used by system min4500
and I have removed all nat statements to try too and no go.
Is anyone aware of an image that doesn't have this issue on the 6500's ?
it makes NAT-T basically useless unless there's something I'm missing.
Tks,
01-17-2021 03:03 AM
Block the port 4500 or any 6500 first from being reserve for NAT overloading
# ip nat settings interface-overload block port tcp 4500 or 6500
then you can use this port in any other command.
09-18-2017 10:57 AM
Had the same issue on a ISR4331 running farely new code, 03.13.07.S/15.4(3)S7 - release long after this bug was identified. I was able to fix via:
- remove all NAT statements
- save
- reboot
- drop in static NAT statements
- put in PAT/Overload NAT
08-27-2019 08:24 AM
This is an old thread, hopefully someone will spot this... I'm having this issue but it's in a colo so my working options are limited...
I assume that removing the overload statement I have will drop my connection but I really need this port translated. Is it possible to enter the nat option in config and reboot to apply it?
11-16-2019 06:18 AM
Well It was a Piece of cake to solve, Just change the local HTTPS port on the Cisco router,
(Conf)# ip http secure-port <New HTTPS Port Number for the Router>
(Conf)#ip nat inside source static tcp <Inside IP> 443 <Outside IP> 443 extendable
You can do the same for HTTP as well, with the ip http port <New HTTP Port Number for the Router>
11-15-2022 12:22 PM
Using your example, I took a little different approach.
(Conf)#no ip http server
(Conf)#no ip http secure-server
(Conf)#ip nat inside source static tcp (Inside IP) 443 (Outside IP) 443 extendable
Work like a top.
02-10-2020 07:44 PM
FYI, to save rebooting you can try this as an example:
Problem is if you have lots of traffic the nat translations will start again before you can remove the overload statement... so
conf t
Put relevant commands in clipboard (with a return after the overload) and paste, paste, paste like a mad person until you remove the overload statement.
do clear ip nat trans * no ip nat inside source route-map INTERNET-NAT interface GigabitEthernet0/0/1 overload
Then at your rules again before adding the overload back.
Still an issue in 16.9.4
01-17-2021 03:02 AM
You need to remove this port from the reserve ports for NAT overloading.
Issue following command to block this port first
# ip nat settings interface-overload block port tcp 5011
Then you can use this port else where.
02-15-2021 03:37 PM
Great info thanks @azwaronline works well and saves having to clear nat!
09-03-2021 08:04 AM
Hello, I get an error when trying to run this command:
4331(config)# ip nat settings interface-overload block port tcp 8211
% Invalid input detected at '^' marker.
09-03-2021 06:58 AM
