CBS350 static route doesn't show on cli
h1pp13p373
Hey Y'all,
I'm configuring a new CBS350 and am just trying to add static routes via the command line, using the usb console.  I set the route, but 'show ip route' doesn't show it:
cisco-peach(config)#ip route 192.168.13.0 255.255.255.0 192.168.7.5 metric 2
cisco-peach(config)#exit
cisco-peach#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
C   192.168.99.0/24 is directly connected, vlan 99
cisco-peach#
When I go to the gui, I can see the route.  (see image attached)
I'm a noob to the cli and would appreciate any advise.
Thanks!
2 Accepted Solutions
pman
please post the config of the router.
you are pointing to next-hop of 192.168.7.5 for network 192.168.13.0 -
In order for the static route to show in routing table the IP address to which you point as next-hop (192.168.7.5 in this case) should be in the same network as one of the interfaces of your router, that interface should be in up state.
I guess that's not the case right now?
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2257-configure-ipv4-static-routes-settings-on-a-switch-through-th.html
it's looks like interface vlan is down because gi2 is down?
192.168.7.4/24     vlan 7    UP/DOWN    Static  disable   No   enable   Valid
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
gi1      1G-Copper      --      --     --     --  Down           --     --
gi2      1G-Copper      --      --     --     --  Down           --     --
from your config:
interface vlan 7
 name trusted
 ip address 192.168.7.4 255.255.255.0
interface GigabitEthernet2
 switchport access vlan 7
ip route 192.168.13.0 /24 192.168.7.5 metric 2
10 Replies 10
pman
Thank You pman!!  I clicked on solved by mistake, but I do have that ip range on a vlan interface.
cisco-peach#show run
config-file-header
cisco-peach
v3.0.0.69 / RCBS3.0_930_770_008
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 7,9,99
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
disable ports leds
ip dhcp server
ip dhcp pool network 42
address low 192.168.42.100 high 192.168.42.254 255.255.255.0
exit
ip dhcp pool network mgmt
address low 192.168.99.100 high 192.168.99.254 255.255.255.0
domain-name lucky.org
dns-server 1.1.1.1
exit
bonjour interface range vlan 1
hostname cisco-peach
username admin password encrypted <edited>
username hippie password encrypted <edited>
ip ssh password-auth
ip ssh pubkey-auth auto-login
crypto key pubkey-chain ssh
user-key hippie-marg rsa
key-string row AAAAB3NzaC1yc2EAAAADAQABAAABAQDeuwwFfnEH
key-string row Ooctt7h+7eLyGlO8+wQP0e38Uu3Y5Y2hVhve6lw6
key-string row hxm/gdaH3h8uRiVGSt2tvo9SV1I+r61P0ivQqGbA
key-string row 8RINKcWqYYkrF0d1ZoiVM5NRVsArLFNo
key-string row VDzjxcskJSPhtNMCDH6gbLM1ck8Vvhi7ftPBncSy
key-string row hvOpxTNGDgHFfvuK2nqyvjDPO7dR1ekvae35/tUZ
key-string row OLzcIeLgU2YUpKtwuFiLE2fZ1eB74cxsT8+9ZdiC
key-string row T0IDwfvk9YIBlr//jflZewIc1XoOAkclHw5Pxfcv
key-string row vbXOT97s0aqqdTT0TphhawMdaoCf2y0ZlV5OzYko
key-string row Uu56+byGnKczTVihWG3N
exit
user-key hippie-sterling rsa
key-string row AAAAB3NzaC1yc2EAAAABIwAAAQEA44qXiwkYCbzB
key-string row U7bXNmIqsYPDdK8Mad43k6bSmXu76pyZ2TVB1e0H
key-string row JkbCIzMUGg9gWDvehVo6tP0D7GDj3el8JVXZMz7c
key-string row vBg76F6ZXHT3MqPfdgINx8nwlz5Kxglt
key-string row aFuhWBtQ5aVolO+8BXGdxAV3rr485WUuvnwLxwWt
key-string row fYUzywXpMk2parTzXBrJszafCKMLDYlVXozWraiV
key-string row 0vs4Wvetfr/f6zd0CiclC/FSPwSQbf208kv+Fz1B
key-string row OHrLjQ4AwcbBXnZy3sB/u+SKQaCuawI11AL6K6nN
key-string row BUw08mApdFixEs8BkgI7MHldUc8hR56uD/vKsRPe
key-string row 7G1iaBaUS/9oryKSnQ==
exit
exit
snmp-server location parlor
snmp-server contact hippiepete
clock timezone EST -4
clock summer-time web recurring usa
sntp server 192.168.42.1
clock dhcp timezone
interface vlan 1
 ip address 192.168.42.10 255.255.255.0
 no ip address dhcp
interface vlan 7
 name trusted
interface vlan 9
 name voip
interface vlan 99
 name mgmt
 ip address 192.168.99.1 255.255.255.0
interface GigabitEthernet9
 switchport access vlan 99
interface GigabitEthernet10
exit
banner login ^C
This is the Dude's network, please abide appropriately.
^C
please post output of "show ip interface" and "show interfaces status"
please add "ip routing" command: switch(config)# ip routing
I had set 'ip routing', but set it again.  Here is the output.
cisco-peach#show ip int
    IP Address        I/F    I/F Status  Type   Directed  Prec Redirect Status
                             admin/oper         Broadcast
192.168.42.10/24   vlan 1    UP/DOWN    Static  disable   No   enable   Valid
192.168.99.1/24    vlan 99   UP/DOWN    Static  disable   No   enable   Valid
cisco-peach#show int status
                                             Flow Link          Back   Mdix
gi3      1G-Copper      --      --     --     --  Down           --     --
gi4      1G-Copper      --      --     --     --  Down           --     --
gi5      1G-Copper      --      --     --     --  Down           --     --
gi6      1G-Copper      --      --     --     --  Down           --     --
gi7      1G-Copper      --      --     --     --  Down           --     --
gi8      1G-Copper      --      --     --     --  Down           --     --
gi9      1G-Combo-C     --      --     --     --  Down           --     --
gi10     1G-Combo-C     --      --     --     --  Down           --     --
                                          Flow    Link
Ch       Type    Duplex  Speed  Neg      control  State
Po1         --     --      --      --       --    Not Present
Po2         --     --      --      --       --    Not Present
Po3         --     --      --      --       --    Not Present
Po4         --     --      --      --       --    Not Present
Po5         --     --      --      --       --    Not Present
Po6         --     --      --      --       --    Not Present
Po7         --     --      --      --       --    Not Present
Po8         --     --      --      --       --    Not Present
                                             Flow Link          Back   Mdix
from your config:
interface vlan 7
 name trusted
All interfaces are down because I'm accessing via the usb console.  Does an interface with an associated ip have to be plugged in to set static routes?  Or would I need to bring it up from cli?
As I mentioned above, the interface should be in the status up (gi2 in this case) from your output we can see that Link Status is Down (Link State = Down for Gi2)
Is a network cable currently connected to Port Gi2?
Ok, I plugged my laptop into gi2 and can see the route now!  So, I guess the 'show ip route' command only shows routes that are active... but the gui showed it either way?
cisco-peach#19-Nov-2021 17:17:11 %LINK-I-Up:  gi2
19-Nov-2021 17:17:11 %LINK-I-Up:  Vlan 7
cisco-peach#shi19-Nov-2021 17:17:15 %STP-W-PORTSTATUS: gi2: STP status Forwarding
C   192.168.7.0/24 is directly connected, vlan 7
S   192.168.13.0/24 [1/2] via 192.168.7.5, 03:21:35, vlan 7
Now I'm cooking with grease.     I unplugged, then added 'static' to my command and voila!  There's the route. Just the learning curve of a noob.   Thanks tons pman!!
cisco-peach#show ip route static
Codes: A - active, I - inactive
I  192.168.13.0/24 [1/2] via 192.168.7.5
Excellent!
I was glad to help!
