CCNA - 3-layered network hierarchy - Routing?
Lukas Hubschmid
Hello forums
I have a question to the 3-layered network hierarchy model of Cisco concerning routing.
Core: fast packet switching, no routing function
Distribution: routing
Access: End devices
I build up the szenario shown in the attached image.
There are two sites in different cities.
C1 = core switch
D1 & D2 = distribution switch
A1 & A2 = access switch
All connections between switches are configured as trunk, allowing VLAN10 and 20 to pass.
PC10 & PC11: VLAN10 (Students)
PC20 & PC21: VLAN20 (Teachers)
Now my question:
On which distribution switch would you do the inter-vlan-routing??
Of course, the computers only can have ONE default gateway configured.
If you use D1, then traffic from PC11 to PC21 have to pass all the way to the other city - not really efficient.
Or is there anything like an "active/active HSRP" setup that BOTH distribution switches are used for inter-vlan routing.
Best regards and thanks in advance,
Lukas
mahmoodmkl
Level 7
Level 7
U can cinfigure one dist switch to be active for one vlan and standby for the other by this u can have load balancing of traffic
Sent from Cisco Technical Support Android App
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Normally, you would NOT pass the site VLANs between your two sites.  You would route on your L3 switches.  Newer designs would normally also route in your core and some of the newer designs would extend routing to your edge.  (In your topology, however, you show the core and access as L2, and distribution as L3.)
If your distribution to core uplinks were routed, you could reuse the same VLAN numbers as each site, but this would avoid spanning the VLANs between sites.
If you do share the VLANs across the sites, some clients' gateway might be at the other site, which as you note, is inefficient.  (Which is a good reason why to avoid spanning L2 across WANs.)
