CCNA Lab Question
Haris Chaudhry
Community Member
HI all ...
I am doing some playing around with my CCNA LAB. I have a Question About Inter-VLan ROuting...
I want to Establish Communication Between the 2 Sites but Prevent Broadcasts and unnecessary traffic across the WAN link. etc...
The links between the ROuters and the Switches are Trunk Links...
Site A has a Scope of 10.130.19.0 /22
Site B has a Scope of 10.137.141.0 /20
So it the Solution as simple as
1. Make a Vlan (5) Called routing with an ip of lets say 192.168.1.1 /29. Make the 2 Switch access ports of that vlan .OR Trunk links with Allow Vlan (5) across trunks and deny all others...
2. Static routes on Routes on the routers 10.130.141.0 /22 192.168.1.1/29 vice-versa ?
Any Ideas which direction i should take ? I am still at very early stages of my CCNA so sorry for my stupid question...
Hello.
I have yet to come across this type of design after so long in the field.
Switches have been created for LAN connectivity and routers for WAN.
I believe you should probably connect the routers together and the switches face tge LAN side.
All other design stays the same.
HTH.
Please rate useful posts.
