OutDiscards on ME-3400 uplink
narinder.thakur
Hi all,
Can anyone advise why packet discard on Me-3400 switch interface and how to prevent.
ME-3400#sh interfaces counters errors
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Fa0/22              0           0           0           0          0            0
Fa0/23              0           0           0           0          0            0
Fa0/24              0           0           0           0          0            0
Gi0/1               0           0           0           0          0      1295422
Gi0/2               0           0           0           0          0            0
ME-3400#show platform port-asic stats drop gigabitEthernet 0/1
  Interface Gi0/1 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 17597741
8 Replies 8
Leo Laohoo
Can you please post the complete output to the following commands:
1.  sh interface Gi0/1; and
2.  sh controller e Gi0/1
Hi Please see the below output
ME-3400#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001d.e55a.9404 (bia 001d.e53a.9404)
  Description: Uplink to ONS node, Ring1
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 14/255
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 100BaseFX-FE SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 8w0d, output hang never
  Last clearing of "show interface" counters 18:07:29
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1295422
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5744000 bits/sec, 534 packets/sec
     16868359 packets input, 20999750940 bytes, 0 no buffer
     Received 1895959 broadcasts (1895959 multicasts)
     0 watchdog, 1895959 multicast, 0 pause input
     2867264 packets output, 3878717837 bytes, 0 underruns
     4470 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
ME-3400#sh controllers ethernet-controller gigabitEthernet 0/1
     Transmit GigabitEthernet0/1              Receive
   3301720825 Bytes                       2155090175 Bytes
    238880299 Unicast frames              2021694196 Unicast frames
      6271171 Multicast frames            1903506910 Multicast frames
           19 Broadcast frames                 28204 Broadcast frames
            0 Too old frames              2926964617 Unicast bytes
            0 Deferred frames              816797850 Multicast bytes
            0 MTU exceeded frames            1805056 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames                 771 Minimum size frames
            0 8 collision frames           743915968 65 to 127 byte frames
            0 9 collision frames          1269583754 128 to 255 byte frames
            0 10 collision frames            3820879 256 to 511 byte frames
            0 11 collision frames                 99 512 to 1023 byte frames
            0 12 collision frames         1907907839 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
           14 64 byte frames                       0 Valid frames, too small
     31815139 127 byte frames
    113920103 255 byte frames                      0 Too old frames
        22109 511 byte frames                      0 Valid oversize frames
        31738 1023 byte frames                     0 System FCS error frames
     99362383 1518 byte frames                     0 RxPortFifoFull drop frame
            3 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
How big is your WAN link?
Its a 1g links, i want to now only why packet drop.. Is it normal ?
QOS config is below.
Class-map match-any output-ABC-network
  match qos-group 3
  match ip precedence 6
class-map match-all output-video
  match qos-group 1
class-map match-all output-A
  match qos-group 2
policy-map input-ABC
 class class-default
   set qos-group 3
policy-map input-video
 class class-default
   set qos-group 1
policy-map POLICE
 class output-ABC-network
    bandwidth percent 47
 class output-A
    bandwidth percent 10
 class output-video
    shape average 33000000
 class class-default
    shape average 10000000
policy-map input-A
 class class-default
   set qos-group 2
Class-map: class-default (match-any)
      4209914 packets
      Match: any
        Output Queue:
          Max queue-limit default threshold: 160
          Tail Packets Drop: 1295422
      Traffic Shaping
        Average Rate Traffic Shaping
        CIR 10000000 (bps)
      Output Queue:
Policy apply in interface (POLICE)
Same thing policy map apply on link2 as well but link two no drops.
Hi ,
Could you please paste the complete output of sh poilicy-map interface gi0/1
Madhu
sh policy-map interface gigabitEthernet 0/1
 GigabitEthernet0/1
  Service-policy output: outpol
    Class-map: A (match-any)
      143793 packets
      Match: qos-group 3
      Match: ip precedence 6
        Bandwidth percent 47    (47000000 bps)
      Output Queue:
        Tail Packets Drop: 0
    Class-map: B (match-all)
      291045 packets
      Match: qos-group 2
        Bandwidth percent 10    (10000000 bps)
      Output Queue:
    Class-map: C (match-all)
      113475 packets
      Match: qos-group 1
      Traffic Shaping
        CIR 33000000 (bps)
      Output Queue:
      13369375 packets
      Match: any
        Output Queue:
          Tail Packets Drop: 2773117
      Traffic Shaping
        CIR 10000000 (bps)
      Output Queue:
Its a 10g links, i want to now only why packet drop.. Is it normal ?
There must be some kind of mistake.  It can't be 10 Gbps links because Gi0/1 is only 100BaseFx.
