CDP-4-DUPLEX_MISMATCH
mvknl
Last weekend we upgraded our Nexus 5K switches to run NX-OS 5.2(1). Since then we see the CDP-4-DUPLEX_MISMATCH messages on several ports while we didn't have these messages on 5.0.3.
We see these messages on several ports with different systems attached:
- WLC 5508
- MDS 9222i
- UCS
For example the MDS 9222i when viewing the configuration:
interface mgmt0
  ip address X.X.X.X 255.255.255.0
  switchport speed 100
  switchport duplex full
And on the nexus:
interface Ethernet108/1/10
  description SAN mgt
  switchport access vlan 851
  speed 100
  duplex full
However, when showing cdp neighbor detail we see the following:
Device ID:SAN(FOX1443GCR1)
System Name:SAN
Interface address(es):
    IPv4 Address: X.X.X.X
Platform: DS-C9222I-K9, Capabilities: Router Switch IGMP Filtering Supports-STP-Dispute
Interface: Ethernet108/1/10, Port ID (outgoing port): mgmt0
Holdtime: 147 sec
Version:
Cisco Nexus Operating System (NX-OS) Software, Version 5.0(1a)
Advertisement Version: 2
Duplex: half
Mgmt address(es):
I don't get it. Why does the switch claim it's half duplex while all physical interfaces are configured full duplex?
Rick Morris
Level 6
Level 6
This is a weird issue that I have seen with servers in the past.  The issue we had was we would set the interfaces to AUTO and it would not negotiate at the correct speed and duplex.  To resolve the issue we had to specify the duplex and speed.  Have you tried to set the interace(s) as auto instead of specifying 100/full?
Yes, we've had it configured every possible way. The interfaces also agree on the correct speed and duplex settings (also when configured auto/auto). But even then CDP will state that there's a duplex mismatch.
