CDP neighbors
vishalpatil86
hi,
i have edge switch to which all my users are connected.
Is there any command to get user's IP like we do in show cdp neighbors r is there any way to do it
pleasw help on this!!!!!!!!!!!
5 Replies 5
milan.kulik
Level 10
Level 10
if it's an L2-only switch, the only way is:
sh ARP
on the default-gateway router.
And correlate with user MAC addresses shown by
sh mac-address-table
on the edge switch.
HTH,
Milan
nkarpysh
Hello Vishal,
No specific tool for that. Though you can do following. Take particular VLAN - you will need to have SVI for that VLAN configured. Ping broadcast address for that subnet (e.g. if subnet is 10.1.1.0 /24 - then broadcast for it is 10.1.1.255). All the hosts withing this subnet will eb ARPed first and then reply to ping.
Then check show ip arp on your switch for this subnet - you will see all the hosts replied and their mac addresses.
Do show mac address-table address MAC_ADDR from above and you will see to whcih port that is connected. You will have to do it one by one or write some script.
Hope this helps,
Nik
HTH,
Niko
fb_webuser
Level 6
Level 6
As I know you can only see the mac-address table on switch. Switch is not interested in end node IPs
Posted by WebUser Aleksandr Yanovskiy
fb_webuser
Level 6
Level 6
Nik, have you ever tried to ping broadcast address in LAN? Most modern OS doesn't reply for broadcast ping
Vishal,
Download nmap and run that. It'll show you all addresses in use and responding.
nmap -sP 192.168.0.0/24
HTH, John *** Please rate all useful posts ***
